Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
My Mitsubishi WD-62725 dlp powers up , no blinking lights, the screen on all inputs is blue with streaking horiz lines and snowball in center screen. Menu works, tuner seams to work but screen goes black and white and there is no audio. Light engine was replaced 3 months ago. what part do you think is the problem Thanks
  • Mitsubishi Master
  • 5,138 Answers
Call Encompass Parts 1800-638-3328 or look them up online they list your TV as well as Service Manual and Keep in Mind just because Light Engine was replaced 3 months ago does not mean it cannot be same Problem so if you have any warranty on it replace it again!
Posted on Nov 18, 2009
SOURCE:
Picture Problem
Model is Mitsubishi WD-62725?
The other question is does it do it on tuner and REAR inputs?
Mar 23, 2012 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
Jul 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Had a solid amber light indicating a new lamp was needed.
Press the menu amd device/input buttons both in together on the front of the set and hold them both in for 6 seconds to see if the timer light will blink a two digit blink code such as 3 blinks, slight pause then 4 blinks. If it blinks that code you will need the V26 Power pwb repair kit which is available at the following link under repair kits and has step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Green timer light keeps blinking
Ross,
Please email me at experttv@comcast.net So i can help you.
Thank you,
Tim Nolan
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
291 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
