Question about Vivitar ViviCam 3780 Digital Camera
Vivitar 3780s keeps shutting down and freezing. battery indicator flashing but batteries were new. was in a cold environment (skiing) Help!
4 Suggested Answers
SOURCE: vivitar
I broke the software cd, there any way to download it online?
Posted on Nov 26, 2007
SOURCE: vivitar vivicam 3780s
Seems the solution is to purchase some lame drive detective software for $30.
NO THANKS.
Posted on Jan 12, 2009
  • 11967 Answers
SOURCE: I want a FREE manual
Have you tried the support section of the Vivitar website?
Posted on Dec 20, 2010
It likes to kill batteries, even new ones.
Unfortunately there is no real solution to this problem other than keeping extra batteries to switch out for the dead ones if you are shooting for a while. Here is what your camera's manual has to say about short battery life:
The battery run time is brief. You are using the camera in a cold environment. Battery performance deteriorates in low temperatures. Keep the camera warm by putting it inside your coat or clothing. - The remaining battery power is not indicated correctly. When battery consumption fluctuates considerably, the camera may turn off without displaying the battery
Sep 01, 2011 | Olympus Camedia C-770 Digital Camera
Have a acer aspire 5520,it has developed several problems,1, will often freeze on full screen mode,have to shut it down and restart,2, will keep on shutting down after battery light starts flashing,will...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5520-5908 Notebook
We have used 1999 Jeep GCL. Key will not turn, nor can be removed. Purchased a used steering column @ salvage yard. Vehicle is at a repair shop. He replaced the steering column, started car, it runs for a...
you know the fuel pressure regulator could cause your vehicle to shut off after a few sec but then you should be able to start it a few secs later then it will do the same thing..computers can be reset unless they are burnt out..
Dec 04, 2008 | 1999 Jeep Cherokee
Vivicam 8400
I have a ViviCam 8400 and have the same problem UNLESS I buy Duracell Power Pix or Energizer Titanium batteries. These cost more than the regular grade AA batteries, but when I used brand new regular batteries, the camera would turn on for 2 seconds then turn right off. Titanium or Power Pix batteries make the camera work fine. And, because they are made for digital media, they do allow you to use the camera for longer periods of time.
Jun 09, 2008 | Vivitar ViviCam 8400 Digital Camera
Vivitar
http://www.vivitar.com/en-us/Support.aspx
Choose your camera from the drop down menu (your camera is there) then choose your language click GO and it will bring you to the page you need to download the driver. Click below the "Driver" name and you will have the option to save or run. You might want to save the file to a flash drive in case you need it in the future. Then run it or just run it from the website.
This should solve your problem
Please don't forget to rate this advice. Thanks!
Dec 19, 2007 | Vivitar ViviCam 3815 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
WONT STAY ON
check your batteries...sometimes cheap batterie or regular batteries do the same to mine...you may need to spend the little extra and purchase batteries for a digital camera ect....good luck
Sep 26, 2007 | Vivitar ViviCam 3780 Digital Camera
How do u charge battery
well u can't "charge your battery", you have to put new ones in
Sep 09, 2007 | Vivitar ViviCam 3785 Digital Camera
Cameras Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
