Question about Toto Aquia II Dual Flush Toilet
After about a year of problem free operation my toilet appears to be having flushing problems. When the tank refills there are intermittant air sucking sounds with bubbles coming up from the bottom. No other obvious signs of problem. Thanks Richard
  • rmussak Nov 19, 2009
    I doubt there is a blockage problem....after talking to the local distributer of these particular toilets and said what I had is a common problem. All I need is to replace the gasket on the left part of the flush mechanism. It is a waranteed part.
  • 11,800 Answers
Incorrect sealing - either the seal itself is faulty or deposits are preventing a total seal. You will have to take it out, clean it and , if necessary, replace the seal.
Posted on Nov 19, 2009
  • Azrael SRL Nov 21, 2009
    You're lucky, the seal was the culprit and it's still in warranty. Don't touch anything on it (it may void the warranty) and call their guys. It should be free of charges.
  • 17,970 Answers
I thing that you have a partial blockage and it sounds like it's in a common drain, (one shared by the rest of the units). That explains the bubbling and back ups but you may also have a blocked vent. A partial clog creates back pressure (bubbles) and a blocked vent will create a vacume (sucking water out of traps and toilet bowls). Have this checked at once.
Reference: Drain-waste-vent_system
Hope helped with this.
Posted on Nov 18, 2009
  • ZJ Limited
    ZJ Limited Nov 19, 2009
    Hi Richard:
    As you tell us...
    This is a good news; I hope helped with this guide, and really hope that you solve your little problem.
    Success!!!
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
Howdy, the tank on my Baden dual flush toilet out of blue eill not refill after being flushed. The water is not filling the tank. Can you help me, this toilet is not even one year old. Thank you. Sue
We have replied that it sounds as if your internal flush kit button is stuck in the down position. If you continue to have problems please contact us for a replacement flush kit for free. Thank you.
Aug 20, 2011 | Dmm Baden Bath One-piece Toilet
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
May 30, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
Toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Dec 26, 2008 | Home
Tank will not refill after you flush
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Nov 16, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Toto Aquia II Dual Flush Toilet Logo
95 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
