Question about Kd Tools 3191 Cv Joint Boot Clamp Tightening Wrench
How do you use cv joint clamp pliers - Kd Tools 3191 Cv Joint Boot Clamp Tightening Wrench
How to change cv joints
I would replace the complete axle assembly,
it would be cheaper and come with a warranty.
Instructions
  1. Remove the CV Joint
    • Remove the boot straps from the CV joint using a standard screwdriver or a pair of diagonal cutting pliers.
    • Slide the boot back over the interconnecting shaft.
    • Get Chevrolet Info at InsideLine Free News, Videos, Photos & More!
      Detach the stop ring at the base of the CV joint assembly using a pair of snap ring pliers.
    • Pull the CV joint assembly from the interconnecting shaft to force the snap ring at the top of the shaft through the CV joint assembly.
    • Tilt the inner cage (the cage holding the balls in place inside the housing) in different angles to remove the six balls. Use your thumb or a hammer and a wooden dowel, if necessary.
    • Tilt the inner cage enough to remove it from its housing.
    • Rotate the race inside the cage--the part that holds the balls against the inner cage--and remove the race from the cage.
      Replace the CV Joint
      • Apply a thick coat of grease to the new CV joint race using special high temperature/high pressure grease (see Tips below).
      • Install the race inside the new cage. Then install the cage/race assembly inside the CV joint housing.
      • Tilt the cage at different angles and fit the new balls in place.
      • Slide a new CV joint rubber boot over the interconnecting shaft.
      • Install a new snap and stop ring on the interconnecting shaft.
      • Push the interconnecting shaft through the CV joint assembly to force the snap ring through the assembly.
      • Apply a thick coat of CV joint grease to all moving parts of the assembly.
      • Apply a coat of CV joint grease to the inside of the rubber boot. Then slide the boot over the CV joint assembly.
      • Install the boot straps at each end of the boot, and tighten the straps using a clamp tool or screwdriver, depending on the type of clamp.
Mar 22, 2012 | 1997 Chevrolet Cavalier
How to use cv joint clamping pliers
you will install the clamp and then put the pleirs over the clamping edge and squeze the pliers to tighten the clamp, if the clamp is an adjustable clamp you would tighten the adjustment as far as it will go then clamp it,heres a picture to show you where to put the pliers jaws. good dayjohnjohn2_136.jpg
Sep 04, 2011 | Kia Sephia Cars & Trucks
How do you get behind the cv shaft to pop it out on driver sid
You will have to get under the car with a pry bar, if you can't get the pry bar behind the end of the joint and between the transaxle housing, you can try gripping it with large slip joint pliers while someone else tries to pry it out against the surface of the pliers. I've even used a c-clamp when I've been alone. Put the clamp on the inner joint and pry against it. Most of the time these shafts will fall out with just a sharp tug just on the shaft itself, but I know some can be a pain.
Feb 21, 2011 | 1998 Dodge Avenger
1993 geo tracker , the front cv joint axles need new boot and bearing. Is it easy for a back yard mechanic?
ITS NOT A HARD JOB TO DO BUT YOU NEED TOOLS LIKE TIE ROD END REMOVING TOOL,YOU NEED SHAP RING PLIERS,YOU NEED HYDRALIC JACK AND AXLE NUT SOCKET 1/2 BREAKER BAR AND A TORQUE WRENCH RANGES TO 200 FT LBS YOU WILL NEED REPAIR MANUAL FOR TORQUE SPECS.THE ,MANUAL WILL SHOW AND TELL YOU HOW TO REMOVE FRONT AXLE SHAFT CV JOINTS.IT WILL LOT CHEAPER TO BUY WHOLE FRONT AXLE WITH NEW CV JOINTS.YOU NEED CV JOINT BOOT CLAMP TOOL AND ITS A WHOLE LOT OF CLEANING INVOLVE PLUS PACKING NEW BEARINGS WITH GREASE.ITS MORE OF HEAD ACHE BEST TO BUY NEW ONE.
Aug 28, 2010 | 1993 Geo Tracker
How to change cv joint boot ford laser 1988
remoce the out board cv joint from the steering knuckle.Remove the clamps from the boot, slide off the cv housing installation is opposite removal, you will need a special tool, to insatall the new clamps.
Apr 24, 2010 | 2006 Ford Laser
CV Joint on Passenger side is going
Nedle nose pliers or O ring pliers do remove CV joint
Dec 31, 2009 | 1998 Ford Windstar
Need to know how to remove cv joint for clutch replacement in 2004 toyota corolla s
Take out the drive-axle. Cut the old rubber-boot clamps off and discard them.
Remove the boot from the inner CV joint nnd slide the tripod from the joint housing.
Remove the snap-ring with a pair of snap-ring pliers.
Drive the tripod the tripod joint from the drive-axle with a brass punch and hammer; careful not to damage the bearing surfaces or splines on the shaft.
Oct 31, 2009 | 2004 Toyota Corolla
My brother is looking for end caps for CV joints for his 1999 Alero
YOU CAN GO TO AUTO PARTS PLACE AND BUY THE CV JOINT BOOTS.YOU HAVE TO BUY THE BOOT CLAMPS CRIMP TOOL.IF YOU ARE GOING TO OVERHAUL YOUR CV JOINT ASSEMBLY.YOU NEED A REPAIR MANUAL TO SHOW YOU HOW TO TAKE CV JOINT APART.CLEAN IT UP AND REPACK.
Oct 13, 2009 | 1999 Oldsmobile Alero
Replacing rear axle dust cover boot on 2005 yamaha grizzly
Inner or outter?? The outter cv joint doesn't come apart. If you rip the outter boot, you need to get a new half shaft. The inner cv joint has a clip inside that you have to take out to split the joint and install a new boot. You also need boot clamp pliers to tighten the clamps or it will come back off first time you ride it.
Jun 19, 2009 | Yamaha XT 660 X Motorcycles
Cv boot clamp came off somehow from the outer hub assembly
athere is a snap ring within the CV joint the nedds to be spread OPEN to release CV joint from axle, Once CV is cleaned and repacked with grease rintall onto axle by again spreading apart clamp. Prior to installing CV joint slide NEW CV joint boot onto axle, Cleanly intall add'l grrease and reinstall CV boot.
Apr 04, 2009 | 1996 Buick Century
Kd Tools 3191 Cv Joint Boot Clamp Tightening Wrench Logo
235 people viewed this question
Top Kd Tools Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Kd Tools Hand Tool Expert? Answer questions, earn points and help others
