Question about Lexmark X3470 All-In-One InkJet Printer
How do i get my lexmark 3400 to print in black and white
    Genius:
  • 1,018 Answers
Set your driver to print "Grayscale Only".
Posted on Nov 18, 2009
Sandy4u
  • 107 Answers
SOURCE: my lexmark x75 only print black and white
Please check color cartridge is ok or not
if it is ok then check your printer configuration in Your pc it should be a gray scale printing ....
Posted on May 23, 2008
frankzjm
  • 191 Answers
SOURCE: Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Posted on Feb 06, 2009
SOURCE: lexmark 3400
ME TOO!!
Posted on Mar 12, 2008
  • 46 Answers
SOURCE: Can't print black and white only with Lexmark 2600!
Hi MikeC,
Most of the time this is due to the black cartridge being out of ink. The Lexmark uses all the colors to create black when the black ink cartridge runs out, but won't let you print black because it is essentially saving ink.
Hope that's the reason and it isn't the printer failing. Good luck! :)
Posted on Sep 23, 2009
Testimonial: "I have discovered that the Black cart is showing up as grey with a question mark on it, (in the Lexmark Service Centre)instead of showing the level."
  • 15 Answers
SOURCE: My Lexmark T640 prints out white text and black
Go to control panel select printers and then select lexmark left click and open printing preferences select graphics tab and uncheck the negative box, the printing will be normal from now on.
Posted on Jun 05, 2010
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
Lexmark prospect - can i print in black and white only when my colour cartridges are empty
The Lexmark Prospect Pro205 requires all the cartridges to have ink in them to continue printing even if your printing in "black and white" only.
Aug 29, 2011 | Lexmark Prospect Pro205 Wireless...
My Lexmark T640 prints out white text and black background instead of black text on white paper
Jun 04, 2010 | Lexmark T640 Laser Printer
Hi MikeC,
Sep 23, 2009 | Lexmark X2600 InkJet Printer
Ink cartridge
If you have a 3470, you need a #1 cartridge. If you have a 3480, you need a #2 cartridge. If it is a 3400 series, there is only one cartridge. It lets you print both in color and in black.
Jan 22, 2009 | Lexmark X3470 All-In-One InkJet Printer
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
LEXMARK 3400 ALL IN ONE
paper feed pulls to the right and there is no paper jammed and the paper guide is set.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
627 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
