Totaline thermostat display is blank. Unlock steps did not help. Can not verify power is getting to thermostat.
  • shanink Nov 18, 2009
    Maybe I missed the point of posting these questions.
    That answer did not give any direction toward a repair. How can I troubleshoot if the tstat is fried or if there is power coming in? I could not get a reading at the wall with the volt meter.
    Total Line does have a lock out option that leaves the screen blank. Found the unlock code on Google but it did not help.
    Thanks anyway.
  • 614 Answers
If a Total Line tstat is blank two reasons No power bad tstat. Rus
Posted on Nov 18, 2009
  • James Stopp
    James Stopp Nov 19, 2009
    What is Model number of Tstat. and model number nad make of air handler. I am really trying to help. I would like to try to solve this problem. Thanks.
  • RGTraveler Sep 29, 2010
    I'm jumping in on this. I bought a bank repo property w/ a Totaline EasyStat thermostat that is blank and I have no manual. It's a Payne furnace is nearly new (No A/C). I'll need heat this winter- any suggestions?
Well i have on as well.just tried to turn it down now it's blank and still running. and the green light is still on
Posted on Jan 30, 2010
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
Totaline P274-1200 flashing all characters
check the conections try contact sprey
May 13, 2014 | Carrier Heating & Cooling
Totaline Thermostate P274-1100 works fine when following programming but when I adjust the temperature manually it will start the furnace and after a few minutes the screen displays E2 error, blanks out,...
E2 is the error code for low line voltage. I would think that this is a erroneous code witch would indicate that the thermostat is defective. do you know if this is true line voltage 120v or transformer voltage 24v?
Mar 05, 2014 | Carrier Totaline P291-1003 Capacitor 10mfd...
Totaline power
I don't know anything about your particular T-stat, but power comes from the transformer and there should be a 3 amp fuse next to the transformer. They're both located in the air handler (where the fan and evaporator coil Is).
Oct 06, 2013 | Heating & Cooling
I walked across my carpet to reset the temperature on my Totaline P/N P474-1050 thermostat. When I touched the thermosat, there was an arc of electricity. The screen went blank and does not respond to any...
There are two options for this. You can try turing all the power off the the unit completely. The inside and outside unit and give it 30 seconds and turn it back on. This may reset it. Chances are you just burned it up. I hate this for you...
Hope it helps.
Jan 28, 2011 | Heating & Cooling
Model # P2740300 totaline thermostat has a blank screen. It's not getting power?
Normally all thermostat functioning with 24 volt. Check power in your thermostat. If not 24 volts, the transformer input where it should be 110/220 volts be there. If yes, your transformer winding open,. Replace transformer. If not,check power.
Dec 27, 2010 | Heating & Cooling
I have a totaline with issues
Replace the batteries first. If that does not fix it, you either have lost 24V from the furnace/airhandler, or the thermostat is bad.
You may get lucky and find that the only problem is a blown 3 or 5 amp fuse on the board. Although that usually indicates a short somewhere in the system.
Jan 30, 2010 | Heating & Cooling
Totaline Thermostat
Hi, My totaline thermostat says EH on it and will only heat. No AC. any suggestions. Previously my AC repairman came out and added Freon into the unit. But did not fix it totally either.
Hot In Atlanta
Oct 26, 2007 | Computers & Internet
Heating & Cooling Logo
2,729 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
