Question about Apple Bluetooth Wireless Mouse m9269zm/a
I cannot right click on my A1015 mouse. That is how i eject the SD disc that is in a card reader.
  • Apple Expert
  • 481 Answers
Under the Apple menu, choose System Preferences, then Keyboard & Mouse (or whichever icon has "Mouse" in it on your release of the OS). Select the "Mouse" tab if necessary. Set the action for the right-click area to "Secondary button."
Posted on Nov 18, 2009
Mu computer is windows 7 professional
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Transfer Pictures From MicroSD Card to PC
How to use card reader
Card Readers Adapters
Memory Card Readers
Aug 20, 2016 | Cameras
How do I transfer things to and from my sd card
Hi, the easiest way is to get anUSB card reader. If you put sd card into reader, (talking about a full sized sd card or a micro in a full size adaptor,) you can insert in multi card reader and attach that to any device with an USBslot. you should be able to find the card, say on a windows computer, by going into windows explorer and clicking on the icon for the sd card. It may be listed as a mass storage device or as an external drive but it should be there. you can put your mouse on the icon and right click , you will see the option to open in a new window. Do this and the sdcard contents should be displayed. Simply click on the file you wish to cut and paste or copy and then put your mouse in the place where you want to transfer and right click again , highlight paste and the job is done. There are many, easy ways of performing file transfers, it is very straightforward. Just be careful not to format your card.
Good Luck
May 29, 2015 | Cameras
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
How to formate my sd dead card
If you are using Windows, simply use file explorer to locate your SD card, then 'right click' on the mouse and select 'Format' - Ensure you format the card with the correct capacity - i.e. 1gig, 4gig etc...
Cheers.
Jul 03, 2010 | SanDisk MobileMate SD Plus 5-in-1 Media...
Dsi cant read the sd card music
WARNING THIS IS VERY HARD: no.1 get a sd card and a sd card reader next open up itunes right click it and it says create a AAC file click it then copy it insert your sd card and paste it to removable disc and if this is failing then right click the song and click info look if its mpeg 4 then you can create a AAC version
Jan 16, 2010 | Nintendo DS Console
When I put the SD card into my camera, i get an error message. And I can't use the card. Is there a way to fix the Card. It's a 2 gig SD Ultra II at 15 mb/s.
Look up how to reformat card or put the card into your computer via card reader, empty trash can and eject normally. Often if you moved a file to the trash can and eject the disc w/o emptying the trash can you can be prevented from using the card.
Sep 22, 2009 | Cameras
Cell phone how do you format the sd card?
just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
Feb 20, 2009 | Nokia Cell Phones
Scan disk card
You need to format it using Right click and then it will surely work.
Dec 08, 2008 | HP Pavilion dv9000z Notebook
Reformat sd card for tomtom one
FIRST THING , Backup the SD card. To format an SD card you insert SD card into card reader slot on a PC or a SD card reader. Then find the SD card Icon in 'my computer'. Then hover over it with the mouse and right click , choose 'format' from that drop-down menue. REMEMBER .... EVERYTHING ON THE CARD WILL BE DELETED ! *** WARNING *** The card will not work in the tomtom once it has been formatted.
Jun 05, 2008 | Tomtom ONE GPS Receiver
Need to reformat micro-sd card in up stage phone
to reformat micro sd card in your phone
go to menu>my stuff>select removable disc or memeory card then select options>format
>>or you can reformat the micro sd card using your pc
>>connect the sd card to the memeory card reader then connect it to the memory card adapter
>>go to my computer then select removable disc then right click then select format
Feb 28, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Apple Bluetooth Wireless Mouse m9269zm/a Logo
1,894 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
