Question about AEG B3101-4 Electric Single Oven
Fan won't knock off.
Once the cooker is switched off,the cooler fan is not knocking off.Stayed on over night.Have had to knock it off at the mains.What is the solution??
Catherine.
    Scholar:
  • 62 Answers
Hi.
the most likely cause is a failure in the cooling fan cut out switch.
It is located underneath the top cover of the oven.
replacement is fairly straight forward.
I have attached a photo so you know what it looks like.
I can supply you one if you have trouble sourcing one.
Just email me on aardvark.repairs@btinternet.com
Regards
Posted on Nov 18, 2009
What would be the problem if the fan is not working in the cooker
There is a Thermal Switch that tells when many appliances turn on the Fan, it could also be the Fan itself is not receiving Power or the Fan has now gone bad. You need to troubleshoot the problem further...
Oct 21, 2014 | Ovens
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
How do i turn the fan off.
If you mean the oven fan that will turn off on control switch.I think you may be talking about the cooling fan.This is to cool the electrical panel on the top front of cooker. It comes on after the oven heats up and may stay running for 15 or 20 minutes after cooker is turned off it will turn off after the unit has cooled down sufficiently for the controller.
Hope I helped.
Good Luck.
May 07, 2010 | Electrolux EOB6636X Ultrafan Electric...
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Jun 24, 2009 | Neff U1721 Double circotherm Electric Oven
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
AEG B3101-4 Electric Single Oven Logo
155 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
