Question about Maxtor DiamondMax Plus 9 200 GB Hard Drive
Obtained a used Maxtor 6Y200P0 (DiamondMax Plus9) hard drive which should have 200GB (as advertised), but only 34GB is available. Reformatted the drive, but still only has 34GB. Verified it is not a jumper, or motherboard, issue. It has been installed in the same computer with a Seagate ST380021A (Barracuda ATA IV), as master. Then, reversed master/slave settings, and still receive the same constriction. I would really appreciate some help with resolving the problem.
    President:
  • 1,149 Answers
Hi:
You didn't say what kind of computer you are installing this drive in, or what operating system, but I can tell by your problem that you are trying to install it with a Windows xp, service pack 1 or older system disk. Often, the older windows disk will not let you see the entire contents of a large disk, and especially a problem if a smaller Hard drive is still present in the system.
A good solution to fix this problem is this:
Temporarily unplug your Seagate hard drive. Download the Maxtor installation software from their website, and then run the installation program. Once you got that, then power down the computer, and do your master slave set up again, and hopefully you will have better results
Posted on Nov 18, 2009
Testimonial: "This was very helpful, and I will be implementing your recommendation shortly. But actually, I was using XP Pro, SP3. The computer is custom built."
11S09N0848ZJ1BLDP019YA
what problem, it is not shinny any more? LOL?
do say. please.
I am clueless, so far due to?
what system? PC, MAC,DVR,ext, TV, moon rocket.(LOL)
what OS?
using it as an internal drive, 2nd drive, or external.?
boot drive?
Seagate bought out MAXTOR.
that number must be a bar code, its not the product number
eg:
so tell me what it is.
as time passes, maxtor, fades to dark at SeaGate.
but this deep search nets, this, (hidden well)
http://www.seagate.com/gb/en/search/?keyword=maxtor
ive been using MAXTOR since day 1.
decodes for Maxtor :
Maxtor
xayb0
xa = drive family
- 6Y = DiamondMax(DM) Plus 9
- 6B = DM10
- 6L = DM10 RoHS compliant version
- 6H = DM11
- 7B = MaxLine(ML)III
- 7L = MLIII RoHS compliant
- 7H = ML Pro
- 4R = DM16
- 2F = Fireball 3
- 6E = DM Plus 8
- 5A = ML II
- 7Y = ML Plus II
y = the capacity of the disk, in gigabytes. Drives less than 100GB will have a leading zero (80GB is denoted as 080, etc)
b = buffer size and interface
- J = 2MB PATA with ball-bearing motor
- L = 2MB PATA with fluid dynamic bearing (FDB) motor
- P = 8MB PATA
- R = 16MB PATA
- M = 8MB SATA
- S = 16MB SATA
- F = 16MB SATA 3gbps
All Maxtor SKUs have a zero at the end. It may have a value, but I'm not aware of one.
Example: A Maxtor drive with a model number of 6Y200P0 is a 200GB 7200RPM PATA drive with an 8MB buffer from the DiamondMax Plus 9 family.
now my generic answer: for all HDD. A+ training....(instructor)
1: i make sure it has +5v and 12vdc power, if not all is hopeless.
2: IF PATA/SATA , i listen to the drive case with my ear.
whirrrrrrrrrrrrrr, no whirrrrrrr ,? its DOA.
if it spins its good. if not its 100% DEAD, (RIP)
3: do the gyro test, (if it fights you, as you change it's direction, then it is spinning) Drive in HAND. (whole deal)
4: does BIOS see it? (MOBO BIOS) hot key hit. RTM on MOBO.
yes, good.
no , DEAD. try another power cord to drive or data cable.
try different data ports. on MOBO.
5: try it on 1 PC, with step 4 and 5
6: if BIOS sees it ,so should WINDOWS. (may)
in the device manager.
and in disk manager. (off computer management CPL)
both. set the drive latter in the latter or it will be hidden.
keep in mind BIOS never tests a drive. it only asks it for
its NAME (PNP) PNP just identiifes the maker and type drive. and its spec. and 1 more tests. it shows the drive is NOT BUSY.
these facts ,help all techs, make good trouble shooting.
Sep 24, 2013 | Maxtor Hard Drive
Tip
Utilizing all 200Gb of my Maxtor 200GB HD
My name is Robert Bostick Sr.
I installed the above listed (200GB) Maxtor hard drive without any problems. However, this is where I discovered that all HD's will only recognize approximatly. 135GB.and that an Adapter PCI PC board would have to be installed to be able to recognize all 200GB. The remainder is not lost, but is installed like a second hard drive, but can only be used as a over flow space or for my music or photos. So, its not entirely bad. However, I want all 200. I have a new WD 80GB I could use for either my music or photos.
I read somewhere that I need a PCI Adapter for the computer to recognize all of the 200GBs. This is what I purchased on line. I purchased a "Rosewill" ATA-133 2-port Adapter with RAID.Part Number RC-200. Will this adapter solve my problem. Looking through all of your people questions Ion your Web Site I''m surprised I did not see a question like this. I guess I'm the only stupid old man out there.
If possible could someone give me a hand with this inherent situation. Also, will the Adapter PCI board I purchased work for this HD,
thanks so much for your time,
Best Regards,
Robert W. Bostick Sr.
bostickr@bellsouth.net
on Mar 13, 2008 | Maxtor DiamondMax 10 200 GB Hard Drive
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
13GB EIDE ULTRA DMA/33 3.5LP 5400RPM
Aug 08, 2010 | Maxtor Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
I have been using the DiamondMax 10 200gb hard drive but all of a sudden my computer does not recognise it
Hope there is no power outage when you are using the system, because if there is power outage it will damage the hard driver and it will not be recongise on the PC it has happen to me more than 2 times.......so the hard disk has crash.
Dec 08, 2009 | Maxtor DiamondMax 10 200 GB Hard Drive
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor one touch usb hard drive
I would remove the hard drive from the case and slave it to my primary drive inside the tower. If it is out of warranty then it is likely old and about to die. Maxtors do not exactly have a reputation for longevity. Your best bet would be to image it and restore the image on a new drive.
Mar 19, 2007 | Maxtor USB 2.0 External Enclosure + Hard...
Maxtor DiamondMax Plus 9 200 GB Hard Drive Logo
304 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
