Question about Sony KDF-E55A20 55 in. LCD Television
No picture. Lamp ligt is on. is it the lamp that
No picture. Lamp ligt is on. is it the lamp that needs replacement
  • 11,361 Answers
Look at the venting grills to see if you can see the whit lights inside. If the screen is black then, there are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 18, 2009
Minolta dialta di620 error 14ao hilp me
Exposure lamp header failure. The exposure lamp is the bright light under the big sheet of glass the comes on to make a copy. Raise the Document feeder and press the start button does the bright ligt come on.
To reset open the front door in the upper left is a small access panel open press the trouble reset. if the code comes back replace the exposure board and lamp
try this place as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 09, 2015 | Minolta DiALTA Di620 All-In-One Laser...
How do I know if my Sony 50e3000 lamp needs replace
Most common indicators are:picture may be dimmer or flickering, or no picture with lamp lite error code flashing, or message on screen indicating lamp needs replaced, lamp 1 year old or older.
Mar 05, 2015 | Sony Televison & Video
My Samsung DLP tv Model HLP6163w/xaa shuts down , the two green and timer red ligts fliker
l need some information here:
Does it work at all or fail upon trying to turn it on?
When was Lamp replaced last and have you inspected the lamp?
Have you or do you hear any high pitched whine or grinding sound or even a loud fan like sound?
Dec 06, 2012 | Samsung Televison & Video
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Tv tuns self off after a few min. lamp light is blinking.
The tv "LAMP" LED light indication flashing or ligting up?Yes,the tv projection lamp live are over.Tv require a new projection lamp.
Jan 08, 2011 | JVC HD-52Z575 52" Rear Projection...
Hello i have a lp690 suddenly the picture dissapeared no ligt in the lamp..It has run 350hours only the power button flashes(green) but no alarm..Should the lamp be changed????
you need to clean and resolder the edge connector on the power supply where it connects to the main board. on this series of prohector, this is a common problem. that and the yellowing of the image due to the frying of the light filter on the blue lcd panel (keep the projector clean and free of dust and you will avoid this, as there are no longer any parts available).
Oct 17, 2009 | InFocus LP 690 Multimedia Projector
High beam not working
yes there is have you checkt the high beam ligts. there is one lamp tho the low beam ligts (50w) usaly and there is one lamp tho the high beam ligts usaly (100w)
Jun 08, 2009 | 1999 Daewoo Nubira
INTERMITTENT PICTURE AND SOUND
You were told correctly, you have a bad lamp. When the lamp gets old, the reflector becomes cloudy and instead of reflecting the light, it converts it into heat. As the lamp heats, it draws more power, eventually too much power and the set "recycles" because the lamp is drawing too much power. Replace the lamp, use an original Sony lamp as the aftermarket replacements are known troublemakers. If the bulb fixes the problem (and I know it will because I fix these TV's everyday) be sure to rate this solution. Thanks!
Nov 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
