Question about HP PSC 1215 All-In-One InkJet Printer
Hi,i got new ink cartridges for psc1215 but when printed,its very faded and looks like the ink is nearly gone?
  • HP Master
  • 6,487 Answers
Do print head alignment using the printer utility installed on your computer, because this can be cause a dirty print head or misaligned print head , after that if still having the same problem, it will be better if you take the cartridge out and then put it back in try to shake it a bit.....
Posted on Nov 18, 2009
Printing faded
you need to make sure you are buying brand new ink cartridges a lot of times they refill ink cartridges and this will happen also make sure you aligine and try to clean them under printer settings.
Aug 29, 2013 | Office Equipment & Supplies
When I print things, the words are faded and all of the letters aren't all there on the page. The letters all run together. Ive checked the ink cartridges and aligned them. Tried to change the font to...
There are two posible reasons for that: 1.Your ink cartridges has run almost out of ink. 2.The ink cartridges head has gone dry or durty. The best you can do is to buy yourself a new ink cartridges.
Oct 28, 2010 | Office Equipment & Supplies
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
Black Ink Faded
Perhaps the print head needs cleaning.
Oct 06, 2017 | Dell 1320c Laser Printer
Faded prints off canon p100
it could the problem with clogged print head try to clean the print head
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 29, 2009 | Canon Office Equipment & Supplies
Ink is fading fast while using brand new ink cartridges
Have you replaced the Drum or is it a BJ-Ink printer?
Nov 11, 2008 | Office Equipment & Supplies
New ink cartridges and still won't print .....streaks and faded ink.
hi ,
-try cleaning it manually - by a lint free cloth and moisten it with water then dub unto the printhead of the cartridge- 4 about 4-6 times,then finish it with a dry cloth-
-then run the cleaning cartridge on the printer
-then print an alignment page
-there is no problem on the printer its just the cartridges
jim
Sep 30, 2008 | Lexmark X1150 All-In-One InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Black ink looks faded!
Providing that the ink cartridges were new and supplied with the printer, the cartridge is defective. I also don't think that you used up all the ink either unless you printed hundreds of documents already. Take the cartridge back to the store where you got the printer from and they should give you a new one.
Oct 29, 2007 | Dell 810 All-In-One InkJet Printer
HP PSC 1215 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
