Question about Sharp UX 300 Plain Paper Thermal transfer Fax
Incoming faxes not coming thru, fax says "line error". How do I fix it?
    Problem Solver:
  • 17 Answers
There is a problem in handling the signals, usually it happens in handshaking. There are some error in the protocols. You have to ask a technician (you did not specify the brand of your machine), chance is, signal levels can be adjusted to as well as the communication speed.
Posted on Dec 07, 2009
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
What does communication error 20 06 mean on my brother intellifax 4750e? We have been having problems faxing out and customers have called with trouble faxing in. Yet, we have received faxes prior to them...
CRC error in answerback. It means the error correction digits didn't match the data that was sent. I've seen a few cases where this was bad phone line conditions - once I could see the phone lines scraping against the gutters in the storm outside the window - but usually it's a flaky Main Board in the fax.
Unplugging all the cables on the board and plugging them back in might clean a bad connection, but we're seldom that lucky.
Jan 27, 2010 | Brother IntelliFAX 4100 Laser Fax
CAN THE MEMORY BE LEAGNTHED ON HP1020 TO HOLD IN MEMORY MORE FOR INCOMING FAXES OR ELIMATE HOLDING RECEIVE FAXES AND PRINT PAGES AS THEY ARE RECIEVED INSTEAD.
I found the manuel on line and found out how to print the faxes in memory to release the memory. So next time a big fax comes thru I will try to print and release faxes from memory.
Nov 13, 2009 | HP 1020 Plain Paper Thermal transfer Fax
WHEN A FAX IS TRYING TO COME THRU, IT RINGS, THEN BEEPS AND SAYS "RECEIVE ERROR"
There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
May 20, 2009 | Samsung Office Equipment & Supplies
Canceling
Unplug the phone line while the fax is coming in and wait for the machine to print out an error report
Dec 01, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Error message 421*
error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
- ERROR CORRECTION MODE to OFF
you can locate this on ADVANCE FAX SET-UP...
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing of incoming faxes
I have the same problem on my hp all-in-one. it looks like a staple went through the copier and it shows on incoming faxes as well...
May 21, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Incoming fax
THE PHONE LINE HAS DISTURBANCE ,PLEASE CALL TELEPHONE COMPANY  TO CHECK...
HAPPY FAXING
OMNIPRESENT
Oct 15, 2007 | Samsung SF-531 Plain Paper Laser Fax
Sharp UX 300 Plain Paper Thermal transfer Fax Logo
111 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
