Question about Sony KP-65WV700 65" Rear Projection HDTV
On a white picture my screen has a yellow color to it and at times mill have a blue blur on the bottom left corner of the screen. also i get blue dots in the middle on the screen.
    Genius:
  • 1,112 Answers
Hello: Seems like you have a picture tube problem. The yellow color is from a weak green crt. I suggest replacing the Red and Green Crt's in this model. They are nortoriuos for Failure especially the Red. The cost for these tube vary from 110.00ea to 150.00each. I don't know if you want to spend that type of money on this set, as i Know this peticular set has an expectional picture quailty, my experience with replacing sony picture tubes, is to replace all three tubes, as the new ones will show brighter. So replacing the red and green crt's and not the blue is not recommened. But thats up to you, you might not notice the color difference yourself. You also have the option of sending the Crt's for refurbished ones or having the originals rebuilt by a company in Calif, called VDC, Video display Corp. They sell and refurbish sony CRTs. This route is much cheaper, the only problem is having the crt's taken out and sent for repair. The other option is to think about purchasing a new set. As this repair price could reach into hundreds of dollars, Around $600 to $700 for parts and Labor..
Posted on Nov 18, 2009
SOURCE:
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 07, 2010 | Car Audio & Video
Yellow arch on bottom left of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 30, 2009 | Toshiba 43H70 43" Rear Projection...
Blue blur in lower left corner & missing blue color eslewhere
panel defective,not worth repair.cost would exceed value of tv.
Jul 29, 2009 | Televison & Video
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but...
the red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Color of the picture
Hi! henori,
This set is out of convergence. Go to your menu button on your remote, press it, then
find convergence and follow the directions for adjusting the convergence.
Toprol
Oct 15, 2007 | Philips 55PW9363 55" Rear Projection...
Green blur bot-R and up-L corner and no audio
If a standard TV has color splotches in 1 or 2 corners of the screen, it is possible that a large magnet, such as a large speaker, is or was near the set and has magnetized the picture tube. The set has a built-in degaussing coil but it is small and will only demagnetize small magnetic fields. Make sure there are no magnets near the set and if the colors are still off, have the picture tube demagnetized with a strong portable demagnetizer. As for the audio, when there are audio output jacks on the back of the set then there is usually an option to turn the speakers off. Some sets have a switch somewhere and some sets have a setting in the audio page of the on-screen menu. Look for a switch or go into the menu, navigate to the audio page and look for a speaker setting (ON / OFF) and make sure the speakers are set to ON.
Aug 28, 2007 | Konka K2386U 23" TV
Sony KP-65WV700 65" Rear Projection HDTV Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
