Question about Polaroid PhotoMax PDC 3070 Digital Camera
Screen comes on nut functions won't work - Polaroid PhotoMax PDC 3070 Digital Camera
How to get bearing out of my king kutter 72"finish mowers, the repair kit comes with snap rings, my has a nut and a star lock washer under the nut. The bearing won't come out of the top of the spi
Without seeing it I can't be sure of your exact problem. But on mine, the washer under the nut has tabs I had to bend down to enable the nut to come off. Then I had to use snap ring pliers to take the snap ring out. Be careful here, as the rings can be under a lot of pressure and they can really fly, so use safety goggles. On that mower deck I was able to hold the blade in place with a piece of 2x4 stuck in the deck, so I was able to loosen the nut with a breaker bar. On my other deck the blade turned, so I had to use a large pipe wrench to hold the shaft on the bottom while I loosened the nut on top. Unless yours is really different, the whole spindle assembly comes out by removing 4 small bolts.nuts. This makes it a lot easier to work out in the open.
Dec 02, 2017 | Cars & Trucks
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Odometer won't work unless headlights turned off, radio lights dim, blinker won't blink all the time now battery light comes on but battery tests good. Intermittent issues getting worse. Horn
You probably have a bad ground in the electronic instrument cluster, or cluster connection to wiring harness. I would recomend you have a qualified auto tech diagnose it. It is not a easy fix.
Mar 16, 2013 | 2000 Ford Expedition
Electric windows won't go up
try to replace the motor. you might have to drill out rivets. if so and you buy new one from parts store, they should come with bolts and nuts. If you get one from junk yard, you would have to buy bolts and nuts.
Aug 19, 2012 | 2000 Dodge Durango
ECHO PB251 BLOWER. Noticed fuel running out of muffler. Cleaned spark screen, installed new airfilter, fuel vent, fuel filter. Ran unit - engine quit while at full rpms - will not start. Clicking noise...
Your flywheel has come loose on enj., this throws the timing off so it is firing at all different times except for when it's supposed to. therefore raw fuel is running right through the cylinder and out exhaust, If you are lucky you won't have to replace the 60.00 flywheel! remove fan side of case,and remove blower wheel, then flywheel nut then flywheel, it has a built in key in it, usually this is wasted from coming loose, make sure you use loctite and an impact to tighten flywheel nut back after you repair/replace flywheel.
Dec 04, 2011 | Garden
Rusted wheel bearing won't come off
easiest way is to heat them with a torch 14- 20 dollars at walmart get it good and hot this should loosen nut then try it, you can also SOAK nut with liquid wrench let it set 15 minutes or so spray again in 30 minutes come back and looen nut , get a good pipe to put around wrench for torch
Sep 04, 2011 | 1997 Plymouth Voyager
Rear wheel won`t come off
Im assuming that you have taken lug nuts off and wheel still isnt coming off. If this is the case. Take all the lug nuts except one off and take a hammer and hit the wheel on the side thats under vehicle and that should pop it off. Hit it and continue rotating it and it will come off.
Jan 31, 2011 | 2001 Ford Taurus
Unlock button screen part won function.
I used to have one of these and i had the same problem. It is because you are supposed to use the little stick that comes with it and not your finger. Instead of locking it that way i found it a lot easier to hold down the back button on the right hand side of the phone to lock it and do the same to unlock it.
Cheers,
Toon.
Oct 01, 2009 | Sony Ericsson P1i
Polaroid PhotoMax PDC 3070 Digital Camera Logo
18 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
