Question about Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S
Where is the ignition module on a 1989 dodge dakota
  • 437 Answers
Your truck has a halls effect pickup coil in the distributor and the single module engine controller is located on the passenger side under the hood. The SMEC is also known as the computer control for the truck.
Posted on Nov 18, 2009
1996 Dodge Dakota,3.9,V6, ignition coil wiring diagram
I think yours has an ignition module which can be checked at parts store. Could also be bad coil. If you must have wiring diagram, get shop manual.
Mar 09, 2014 | 1996 Dodge Dakota
Where is the ignition control module dakota 4.7 2006
The ignition module is built into the powertrain control module / computer.
Jan 27, 2013 | 2006 Dodge Dakota
Where is the ignition control module located on a 1991 Dodge Dakota?
Hello
The ignition control module is part of the ECM engine computer which is located under the hood.
Nov 01, 2011 | 1991 Dodge Dakota
I need a diagram of the bracket positions & mounting of the Power Steering pump for a 1989 Dodge Dakota 2wd - 4cylinder 2.5
Yes there is complete guide available for power steering pump and bracket positions mounting.Its will all details and diagram and lot more details.Please click on link below.Check the details http://technoanswers.blogspot.com/2011/03/1989-dodge-dakota-2wd-4cylinder-25.html ------------------ In this link is complete guide for steering and suspension of 1989 Dodge Dakota 2wd - 4cylinder 2.5------------------ This should help. Thanks.Helpmech.
Mar 29, 2011 | 1989 Dodge Dakota 2WD
How do you replace the ignition switch on a 1989 dodge dakota?
Remove the steering column cover,I believe a long T20 Torx Bit
Then same Torx, for switch
Your not doing the key cylinder
Dec 07, 2010 | 1989 Dodge Dakota 2WD
How do you change the ignition lock cylinder on a 1990 dodge dakota?
I just recently had to replace the ignition lock cylinder on a 1990 Dodge Dakota. If yours is anything like mine the ignition lock cylinder you need is for a 1989 Dodge Dakota. All you have to do to replace it is remove the center of the steering wheel and the steering wheel. Next you will have to remove the lock plate. After you do that you should be able to pull everything else out of the way. Then all you have to do is take a flathead screw driver and pop the old ignition out. You will need a steering wheel puller and a steering wheel lock plate remover. The best thing to do with the lock cylinder is to go to autozone or whatever store you use and match it up. Good luck
Nov 28, 2010 | 1990 Dodge Dakota
Firing order 1989 dodge dakota
1989 Dodge Dakota 3.9 liter V-6 VIN "X"
Hope helps (remember rated and comment this).
Aug 16, 2010 | 1989 Dodge Dakota 2WD
Lost ignition...turns over but no spark
make sure that the distributor module is ok first.Check that the ign coil is getting a pulse signal when engine is turning,and check ecm fuse and that engine is grounded to frame.
Nov 25, 2008 | 1989 Dodge Dakota 2WD
Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S Logo
186 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
