Question about Samsung HL-P5063W 50" Rear Projection HDTV
The tv makes a loud noise - timer/lamp lights light up but no picture/sound. Changed bulb - tv worked for a short while. Now issues starting all over again. What could be causing this?
  • Samsung Master
  • 5,138 Answers
Ballast Board that connects to Lamp it could be bad or recheck to make sure its pluged in good anyway Ballast Board is what turns Lamp on Loud Noise means Color Wheel which can also shut set off Id say Color Wheel Call Encompass Parts 1-800-638-3328 they List all the Parts you need Part# for color wheel is BP96-00674A cost 129.69 They also have Service Maualfor your TV. Also Look on E-Bay under Electronics found some good deals thier Got my Lamp for 85.00 and Ballast Board for 65.00
Posted on Nov 18, 2009
Replaced lamp
There is some short circuit at the main circuit board. Seek help of any experienced service technician.
Aug 01, 2012 | Samsung HL-P6163W 61" TV
Loud pop
Check the lamp.
Pull it out and look at it.
More than likely the lamp has shattered inside the set and needs replaced.
Bulb replacement is made for consumers and can easily be replaced.
Need any more information, respond to this post and I will reply.
Dec 30, 2007 | Panasonic PT-45LC12 45" Rear Projection...
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My samsung tv was making a loud wining noise then a pop.
you need to replace the lamp and if you have , you now need to reset the lamp use timer, so that it can start the new timer on the new lamp.
Jul 05, 2009 | Samsung HL-67A510 67" DLP HDTV
Loud whinning noise then no picture or sound
Color wheel is the noise you are hearing. It can also keep the lamp from firing up if it has seized up. Remove the lamp and inspect it. Replace the color wheel for sure.
Jan 10, 2009 | Samsung HL-R5678W 56" Television
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
121 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
