Question about Brother MFC-5440CN All-In-One InkJet Printer
Error message says unable to clean. print head is stuck at far right side. how can I release print head? Thanks. Jim
  • Jim M Nov 18, 2009
    Thanks! This solution got the printer working again:
    Thanks, cene765.
    Best Solutionposted on Oct 28, 2009
    cene765
    Rank: Guru Expert
    Rating: 89%, 343 votes
    Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
    Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
    is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
    annoying cannot clean message.
  • Anonymous Mar 13, 2014
    head stuck on the right side
    Welcome Back:
    Visited the website for 2 consecutive days.
Nov 18, 2009 - Thanks! This solution got the printer working again: Thanks, cene765. Best Solutionposted on Oct 28, 2009 cene765 Rank: Guru Expert Rating: 89%, 343 votes Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this: Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message
Posted on Nov 24, 2009
Unable to print 48
Clean the plastic encoder strip thoroughly
In order to access both ends please follow these steps
1. After the error message is displayed on the LCD or display, open the scanner cover, so the print head is visible.
2. Press and hold the Stop/Exit key for 5 seconds. The print head will move to the middle.
3. Unplug the power cord from the power outlet.
4. Use a clean lint free cloth dampend with a bit of alchohol and clean both sides of the encoder strip thoroughly. Move the print head from side to side to allow access for cleaning of the entire encoder strip.
Feb 25, 2014 | Brother MFC 6490CW InkJet Printer
6c10 error code how can i fix this
error says that either something is jammed in the purge assembly, the unit on the right that cleans the print-head, or the purge assembly is stuck or broken. If you unplug the printer with the carriage in the center you can use a flashlight to inspect the area on the far right where the print-head parks.
try this>
# Start with printer off
# Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
# While holding the Power button, release the Resume Button.
# Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
# Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
# Turn off the printer and turn on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Can I reset the printer head on my Brother DCP-310CN printer. I'm getting an error message "unable to clean" & the print head is stuck to the right of the machine.
Same problem ,head over to right side- stuck - spent an hour and decided to dump it ,time better spent getting new, thats it, sorry
Apr 05, 2010 | Brother DCP-310CN All-In-One InkJet...
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Aug 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to print error message, platen head unaccessible on right
this is the most likely problem
This error is usually caused by the Carriage Encoder Strip being dislodged from
the sensor mounted on the Print Head/Carriage Assembly.
you will need to put the encoder strip back into the slot of the print head
May 06, 2009 | Office Equipment & Supplies
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Message shows: install correct print head
After you do what the error message says then you have to go through the keyboard and clear the error as per the user manual instructions. God bless.
Jan 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Message
That is a problem with the print head tilt or side to side movement.First remove the right and left covers. Then on look on the left side ( looking at the machine from the front). About mid way back toward the bottom of the frams you will see a stainless steel block, about 1 inch square. See if there is ink in it. Normally you will see some yellow ink buildup in that block. There is a spring on a bracket that you have to slip off to remove and clean the block. If excessivly filled witih ink you may have to use some channel lock pliers to remove it. Soak the block in some pretty warm to hot water to slften the ink and clean the block and shafe off thoroughly. Then clean the print head shaft and remove as much loose ink as possible.
The second most likely problem is that the print head wiper blade has stuck to the print head. You then have to remove the ink loader, ( where you insert the ink sticks. Once that is removed you can access the print head/drum area. The blade is pink in color and if tacked to the print head, remove gently. Then run a couple of cleaning cycles and also the remove light stripes cycle. The blade will mostly stick if the machine it shut off improperly or there is a power failure. The clutch that drives the wipe may be bad, although far less likely.
Those are the 2 most common problems that give that code. I would say those 2 resolve that problem more than 70 percent of the time. But that code means the print head is not moving side to side or front to ack properly.
Hope this helps , it should.
Nov 14, 2008 | Xerox Phaser 8550DT Thermal Printer
Error message
does it say an error after "unable to print",what lights? are all inks good?, is there any bits of torn paper inside where head and carriage side up and down?
Oct 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
614 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
