Question about GE (PSS26MSRSS) Side by Side Refrigerator
Last night my ge refridge started shooting sparks out the back and at the bottom.. i unpluged it is this a common problem. can anyone tell how to fix it the cheap way thanks
    Scholar:
  • 79 Answers
You have a wire that has either broken off or burn't off and has shorted to ground or is arcing. You need to take the back bottom panel off and find the wire. It most likely is at the compressor or the condenser fan motor. And , no, it isn't a common problem. I hope I was able to help you! Good luck.
Posted on Nov 18, 2009
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
I have a Roper side by side refridge-freezer. We smelled an electrical smell last night. Today the freezer/icemaker thawed out and the refridge also did not cool. I have pulled the back off and checked...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Roper Refrigerators
Smelled electrical burning last night and unplugged my GE profile dryer and one of the prongs(3 prong type) was burned
This usually indicates a loose connection. Check the wire connection inside the outlet and the connections on the back of the dryer. Make sure the nuts are not cross threaded, this commonly happens with the fine thread. When a loose connection happens the electricity will generate heat trying to make the connection, the cause of many home fires every year.
Oct 15, 2010 | GE Profile Harmony DPGT750EC Electric...
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
Freezer is at 20 degrees and refridge is at 75
make sure the fan is working inside...might be why it frosted up to begin with
Oct 06, 2009 | Refrigerators
GE Refridge #tbx21jablraa Water collecting in
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
Sep 24, 2009 | Refrigerators
Amana ABB2224DEW bottom freezer defrost problem
You have a defrost problem. You will need to replace your defrost system. Before you put the parts on, you need to completely thaw out your unit. You can do this by leaving it open all day or night or by placing a fan close to it with the door open. We have parts, so please give us a call and we'll be sure to ge the right parts out to you right away. We look forward to hearing back from you.
Sep 16, 2009 | Amana ABB1927DE Bottom Freezer...
I have a 4 years old GE top loading washer - model number 2090D... it was fine till last night that it stop at the last ''drain and spin'' cycle... and I smell a burn smell too when I notice the washer...
  It may be possiblr by the way you explained the symptoms, that the tomer may have shorted out .That would be the most likely problem of the burning smell,and the case of no water entering the tub .
May 02, 2009 | Washing Machines
HELP! Fire Hazzard!
It sounds like your focus/screen block, the flyback transformer, or maybe a CRT anode lead is leaking high voltage. This could be a serious problem, or could be a simple one. You should not attempt this repair unless you know all of the high voltage safety issues involved with this TV set. Good Luck
Jun 20, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
