Question about InFocus IN36 Projector
How is look like inside of INFOCUS IN36
How its look like inside of INFOCUS IN36
I need the service manual
Thank you
  • 2,237 Answers
Infocus IN36. When I plug it in the wall, all the maintenance lights come on and nothing happens, The fans are running.
your bulb is more than likely out. take it to your local repair shop and they will be able to tell you, or if you are savvy enough take the bulb out and and look at it, WARNING: the bulb contains mercury so prior to removing the bulb, as a precaution, put on some latex gloves. Also make sure that you unplug it first and discharge the capacitors by pressing the power button a couple of times. If the bulb is bad it will have more than likely cracked or shattered, or in some cases just have a silverish Rainbow burn on the bulb itself.
Jul 02, 2011 | InFocus IN36 Projector
Projector Works for one minute then the lamp goes out.
sounds like a fan not working or a bad power supply/ballast. If it is a fan that is not working it will cause it to shut down. That would either be a bad fan or bad main board. But, if all fans are working, most likely it's the power supply/ballast.
May 10, 2010 | InFocus IN36 Projector
The Infocus logo image is up-side-down even without connecting to the computer.
Many projectors allow you to vertically flip the image for mounting the projectors upside down. Each projector is different in how to change that setting, so I would look in your owners manual.
Mar 11, 2010 | InFocus IN36 Projector
LP70 infocus projector is casting a shadow on the left side of the screen. It seems as if something is blocking the lens from inside? Could this be a bulb issue?
the light tunnel is collapsing and need to be replaced. you could get the part from an infocus service center and do it yourself or send it in to one and have them repair it. speaking from experience, it's a quite involved repair. you have to basically take the whole thing apart to get to it, and make adjustment to it really close to the power supply while it's on. kinda risky. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 15, 2009 | InFocus LP70+ Multimedia Projector
Turn projector on and the bulb turns off. The
ballast/power supply issue. needs replacing.
Oct 05, 2009 | InFocus IN36 Projector
Displays only narrow horizontal band of light on screen do you have any ideas
What you haveis most likely a horizontal collapse, You will have to take the unit in and have it repaired, go to a trusted techie though, Its most likely just a "cold solder joint," few minutes to fix if that is it and if the tech will admit that it is something so simple.
If you take your hand and hit the side of the projector does the line react at all? If it flashes even slightly then you are on the right track
Unfortunately a cold solder joint can sometimes be difficult to locate and due to the intigration you can no longer just check the horizontal control sect of the board....You may try asking the tech If he/she believes it "may" be a cold solder joint......good luck
May 22, 2009 | InFocus IN36 Projector
Picture is upside down
flip the projector over
Apr 30, 2008 | InFocus IN36 Projector
InFocus IN36 Projector Logo
220 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
