Question about HP G60-235DX Notebook
Stop responding HP DVDplayer program stopped responding
Chamberlain 1/2 hp opener stops intermittently during travel.
could be that the remote operation or cycle operation needs reprogramming as it indicates that the program has a corruption in it and the action is lost by that corruption
follow the user manual and do the reprogram sequence
Jul 09, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
Tip
How to avoid losing your work in case a program stops responding
Sometimes, while doing some specific work on your PC or browsing the internet, the program you're using suddenly stops responding without any apparent reason. If you hadn't been saving your work regularly, you'll most likely lose it when Windows prompts you to close the program.
There's however a solution that could help you avoid such frustration. Here are the steps to follow in case a program stops responding :
1. Once you encounter such a problem, don't close the program you're using.
2. Open the Task Manager by pressing Ctrl + Alt + Delete.
3. In the "Processes" tab, find "explorer.exe", choose it and click "End Process" on the bottom right.
4. Click "Yes" (Everything you see in the background will disappear but don't panic, it will come back).
5. Click "File" on the top left.
4. Choose "New Task (Run...)"
5. Write "explorer.exe" in the box.
And everything comes back! You can now resume your work...
on Sep 28, 2010 | Computers & Internet
Program to stop running on my PC screen
Try opening the task manager and ending the program from there: press control and alt together and then press delete. Choose to open the task manager. On the applications tab, highlight the program you want to stop and click end task. If you get a window saying the program is not responding, click; end now. After this go to the start menu and type msconfig into the search field and return. Open the tab that says startup programs, find the HP program and uncheck the box. Restart the machine. You can then go to the control panel, choose remove a program, highlight the HP program and click uninstall.
Mar 28, 2012 | Computers & Internet
My HP Pavilion Entertainment PC's screen constantly freezes. Sometimes I can't click on anything, but the mouse still moves. Help!
If your notebook locks up or stops responding while using a program, close the stalled program to continue using other programs. Also, while closing the program, take note of which other programs are running at the same time.
Please check the link below to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00825363&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jun 13, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
My hp note book stops responding during on
if it is when starting the comupter then you may have attached any hardware which is not compatible with the computer. So, remove any external devices or recently attached devices.
If the computer stops responding after you enter the user ID and password, then it is due to another program which is blocking the functionality of the computer. You can perform a clean boot to resolve this issue.
Clean boot: http://support.microsoft.com/kb/929135
Mar 05, 2010 | HP Pavilion dv4-1120us Notebook
Daewoo dvdplayer/vcr combo switct over switch not
that happend to me and we had to take it apart to figure out the problem.
Jul 14, 2009 | Daewoo DV-6T834 DVD Player/VCR
Problem
I understand that when you try to increase the volume the programs freezes.
To isolate the issue please uninstall HP Quick Touch Software.
Here are the steps to uninstall HP Quick Touch Software.
Click start and select Control Panel
Then select Programs
Then select Programs and Features.
This will show list of programs
There select HP Quick Touch Software and click on uninstall/Remove.
Then restart the Notebook . This should resolve the issue.
Thanks.
Aug 21, 2008 | HP Pavilion dv9000z Notebook
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
HP G60-235DX Notebook Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
