Question about Cell Phones
How do i open the compartment and remove battery and si. I have a problem with the screen it is very dull and hardly readable. The O2 shop said remove battery and sim and give a wipe off. The sim is 2 1/2 yrs old and a 2g sim and the phone is a 3g phone.
I cannot get the battery compartment open on remote. Samsung UN50jU7100F
Samsung cannot open battery cover Remote Controls ...
www.fixya.com > ... > cannot open battery cover > Remote Controls
Samsung remote controls cannot open battery cover related questions and answers. Ask your Samsung questions. Get free help from remote control experts.
How can I solve if the remote control is not ... - Samsung
www.samsung.com/sa_en/support/skp/faq/239888
Samsung ElectronicsDec 11, 2014 - 1) Open the battery compartment on the back of the remote and ... If you have any digital camera (including a camera phone), you can test any ...
Remote Control Issues - samsung product support network
Jan 12, 2016 | Samsung Televison & Video
Is there an adjustment screw for top screen?? My top screen is have issues with black. The screen is not always readable..Out of focus with kinda dark green instead of black. Already replaced it twice....
The adjustment for the upper LCD is in the battery compartment, open it up, remove the battery. you will see 2 adjustment screw at the bottom, using a precision screw driver, turn it very slowly and don't push it.
Put back the battery, turn it on, adjust it again if you are not satisfied.
Hope that helps you!
Aug 07, 2011 | Nintendo DS Lite Console
I want to change the harddisk, but I can not get the computer opened in order to so. Any suggestions?
In order to change the hard drive on this laptop you are going to have the remove the battery and the keyboard because the hard drive is directly under the keys. When you remove the battery you will see 3 screws, remove them. Open the screen and flip the laptop over to see, in the battery compartment, the keyboard release access. Insert a flexible tool and press inward to release the keyboard. Flip the laptop over and gently lift up the top part of the keyboard until it releases. You will see you have the hard drive there. Unscrew it, remove the bracket and replace the hard drive. Be careful not to loose any screws and never force a screw back into place.
Jul 06, 2011 | Compaq Mini 110c-1001NR Notebook
I have had a toshiba A75 Satellite and it just will not stay on. Is there anything that can be done to keep this things on. I have replace all the suggested parts. What can I expect from a repair shop? ...
there are two compartments on the underside of the laptop... unscrew both... remove the battery from its compartment... canned air can be used but not recommended due to the fact it just does not blow hard enough... use an air compressor instead with a blow out nozzle... if you don't have immediate or quick access to one... go to the nearest tire shop or tire repair shop and kindly ask if you can use their blow out nozzle... blow air in all vents , fans, and open compartments on the underside... after blowing out all debris and dust... replace the screws to the underside compartments, replace the battery back in its compartment... plug in your unit and press the power button. thats it! your problem should be solved... this problem may occur again... but now you know what to do.
Dec 29, 2010 | Toshiba Satellite A75-S211 Notebook
Screen is not readable- thinking it's the battery
Have you tried to adjust the contrast on your display? If that doesn't help chances are its your battery.
how to change battery:
Remove the battery compartment door, the bottom half of the back, should slide down.
Disconnect the cord attached to the battery pack and remove the battery pack from the handset.
Insert the new battery pack and connect the cord to the jack inside the battery compartment.
Put the battery compartment door back on.
Jun 18, 2009 | Uniden Cordless Phone
Laptop screen is barely readable, cannot not determine location of cursor.
The first thing to check is brightness of your IBM. May be the brightness is set very low. It may sound silly and simple, but we human can overlook simple issue.
Secondly, try using another charger. Not the battery. Recently, I had problems with one of laptop same model. I formatted and reinstalled windows etc...nothing helps. Just curios, changed the charger and surprise me...It worked alright.
Regards,
Maha
Feb 05, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
LGShine dull screen
Yes a new phone is required here as the LCD has been damaged by the water
Jan 02, 2009 | LG Shine KE970 Cellular Phone
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
Apr 24, 2008 | O2 Xda IIs Pocket PC
My o2 celphone won't turn on
O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
*Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
i hope it will help your prob.
Dec 01, 2007 | O2 XDA Mini S Smartphone
i am having the same problem, my screen apears to be pretty nuch black until i have to tilt it up to be able to slightly read the dark screen.
May 24, 2007 | IBM ThinkPad R51 Notebook
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
