Question about Acer Aspire 5002WLMi Notebook
Upper number keys are locked and the fn will not clear as well the cap lock is reversed this is acer notebook
SOURCE: Embedded numeric keypad
To toggle the embedded numberic keypad Hold down the blue Fn (function) key and press NumLk.
Posted on Oct 25, 2007
ebay312
  • 118 Answers
SOURCE: FN + F11 "turned on" at boot up
This feature is turned on and off in the system BIOS.
During startup, hit either the DEL or the F2 key to enter the setup.
Read through the items found there until you find the keyboard options.
good luck.
tony
Posted on May 19, 2009
  • 12 Answers
SOURCE: May 22, 2010 Using Fn + f7 to unlock Acer 5100 Asp...
There're no free support. Acer will charge $60 for a 30 minutes phone consultation. $200 for unlimited consultation. They will fix it if it's still under warranty. You can also send it to their repair center. It will cost probably $200 also for them to fix it. Try this:
1. go to device manager
2. Highlite USB host controller
3. Click On the "Action" Tab at the top
4. Click on "Scan for harware changes"
5. Restart your laptop.
Let me know how you make out. Good luck! :)
Posted on Jun 19, 2010
SOURCE: Hi i bought a Acer
The green key used by enabled function key......
Posted on Aug 19, 2010
SOURCE: acer aspire model 5742z-4646 embedded
try to disable from the bios
normally has pheonix bios
try
https://computinghardware.web.cern.ch/ComputingHardware/doc/NEC/M360-UserGuide/um/BIOS_KW3_rev1_01.pdf
Posted on Sep 05, 2011
Keyboard will only type numbers
press and hold Fn key and NumLK key (blue keys) then release number lock
Aug 14, 2011 | Acer Aspire One PC Notebook
Hello, for the keys "Fn" is
Hi
Have you tried pressing the No lock or the FN+number lock
on my acer it is on the top of my keyboard on the F11 key
so i would press either the F11 key or try FN+F11
hope this helps your
Feb 04, 2011 | Fujitsu LifeBook S7010 Notebook
Text has changed to numbers
The keyboard on this model and lots of others have a built in 10 key number pad that is activated by a key combination. In this case num lock activated by pressing Fn+Scroll. The Fn key is to the right of the left Ctrl key and the Scroll key is in the top row upper right hand corner and doubles as the num lock key when the Fn key is pressed at the same time.
Nov 14, 2010 | Compaq Presario 700 470024-192 Notebook
Vostro 1000 Fn locked
This is ****. Respondent doesn't know the model in question and his suggestion is of no help--there is no "blue lock" graphic imprinted anywhere on the Vostro 1000 keyboard. A user with this sort of question is already frustrated and does not need his desperation exacerbated by a nonsensical response from someone calling himself "RescueTech".
The user, on the other hand, may be excused for believing the problem is a locked Fn key--Dell does you no favours by printing the alternate number labelling in blue, AND the problem is reversed as long as the Fn key is held down--but the actual culprit is Num Lk. You'll find it on the top-most row, five keys from the upper-right-hand corner. Press it once and your problem will vanish.
Apr 03, 2010 | Dell Vostro 1000 Notebook
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
The keyboard on my ACER Aspire is stuck in a mode...
Find the key that says num lock, press the Fn key and the num lock key to turn off the number lock.
Jun 16, 2009 | Acer Aspire 3000 Notebook
Number keys locked but number lock key is not releasing them
Try holding the Fn key down and then press numlock.
Mar 18, 2009 | Acer Aspire 5100 Notebook
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
Cant find the number lock key on my acer 6920 laptop
I think for your laptop the number lock key is a second function... Try holding down the function (Fn) key and pressing the F11 key, hopefully that will turn your number lock on/off.
Nov 23, 2008 | Acer Aspire 5100 Notebook
Open Questions:
Acer Aspire 5002WLMi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
