Question about Sony Playstation 3 (PS3) Console
It will turn on but i cant get it to come on the tv?? there is only a green light ??
I cant seem to power on
Try pressing and holding the button for a second or two. You may also try using a remote control to power on the tv
Jan 06, 2015 | Televison & Video
Tv keeps turning off by itself
See if you can clean out like a computer they can get dusty and over heat
Jun 07, 2012 | Haier HL32D1 32 in. TV
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Red/green light keeps blinking.
This issue is related to a bad/failed power supply inside your TV.
Call LG to see if your TV is still in warranty. 800-243-0000
If not in warranty, the power supply is about $225.
Good luck. I do hope that I have helped you.
Jun 27, 2010 | LG 42LC2D 42 in. LCD HDTV
I cant ge the tv to turn on. When I press the
go to the tv and try if i dont work try to unplug your cablebox
Feb 06, 2010 | Sony RM-Y914 Remote Control
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Tv turns on but nothing will work
If the green light come on but you cant get the menu to populate then the video board has gone out. We have installed hundreds of these in commercial applications and this has happened a few times. New LG LCDs in that size range are around 399 which is close to what it would cost to have it repaired (probably around $240.)
Nov 23, 2009 | LG 32LG30 32 in. LCD HDTV
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Cant turn on my tv
There's a short in there somewhere. Have a pro look at it.
Mar 25, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
