Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig model TFX20JRBK ww with icing on freezer
GE Frig model TFX20JRBK ww (serrial DZ266727) with icing on freezer back wall. Frig runs a lot. Fix it or buy a new one?
  • lalo_1948 May 11, 2010
    One of 3 things. Defrost timer could be bad but most likely it is the defrost heaters in the freezer
  • GE Master
  • 1,606 Answers
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Posted on Nov 18, 2009
  • Mike Smith
    Mike Smith Nov 18, 2009
    The heater kit , runs about $ 60.00 . Also , it may have changed recently , from 2 heaters to 1 ( but still , with the defrost thermostat ) .
  • Rex Bahr
    Rex Bahr Jan 26, 2017
    One pickup is on the copper outlet and the other is on the aluminum right before the copper tube. Where is a schematic? Rex
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm frig and cold freezer
usualy a defrost problem check for ice on back wall in freezer thats most common problem check for ice on wall in freezer ice build up is due to defrost system failure
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side ffreezer continues to frost over
A simple defrost may not be all that is needed. There is a piece that connects to the coils called a defrost timer or a " clixon " This is most likely the problem. Have it replaced and that should get you back in business. Hope this helps. Good luck.
Jul 09, 2009 | GE Refrigerators
Freezer frosts up and stops cooling after approximately 2 weeks
either low in freon or defrost timer stuck or unit needs cleaning, remove front louver panel on bottom (either 2 screws or snap fit) look for timer then use small straight screwdriver to turn slowly till clicks then wait to see if working properly, if not could be problem. if you see a lot of dust bunnies while doing then clean with vacuum and do same to back area also
Jun 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cool enough even on higher settings
I posted this on another problem, but this may help you too.
Check to see if there is frost on the back panel of the freezer.
If there is try solution below:
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE GSS20IEP Side by Side Refrigerator
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Hot
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
GE side by side W/ ice and water dispense
If you have ice forming on the back of the freezer wall it is an indication of a problem with the defrost cycle.Could be defrost timer,hear or termination swith.
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,008 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
