Question about Lexmark Optra C710 Laser Printer
Lexmark Optra C710 keeps on having paper jams
Our C710 keeps on getting paper jams. The paper is then always stuck in the compartment just after the fuser rollers. It looks like it does not make the 90 degrees turn in those cases. The paper always all crinkled up afterwards.
both a new transfer belt and fuser rollers were installed recently.
Any idea what could cause this problem?
  • 1 more comment
  • Ronald_j Jan 10, 2008
    What exactly do you mean with the rear door? The fuser is all the way at the front of the printer.
    I tried to put paper painters tape over the inside of the fuser cover to smoothen it, as the paper is guided into its 90 degrees turn by this. This had no effect.
  • Ronald_j Jan 11, 2008
    Weight is 80Gr/sqM. I am not sure about the finish. It does not say on the package.
    I have the following data:
    Mondi Business paper
    Ideal Quality, economy
    for Laser, Inkjet printers and copiers
    ISO9706
    I was thinking that the rollers attached to the door might fail to grab the paper. But I cannot see what exactly goes wrong as the door is closed when it happens and unfortunately it is no transparent.
    Next time when it happens I will try to open the door very slowly and catch a glimpse of how exactly the paper is jammed.
    Master:
  • 788 Answers
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Posted on Jan 10, 2008
  • 1 more comment
  • Dean Joly
    Dean Joly Jan 11, 2008
    I've seen this kind of problem caused by the incorrect paper being used. What weight and finish of paper are you using?
  • Dean Joly
    Ok, probably not paper then. Must be something with that door since you have a new fuser.
    There might be a bad sensor though but that is rare.
    Examine the exact area when the leading edge of the paper gets stuck, something has got to be out of place or broken. A replacement door might be a good option that shouldn't cost too much.
  • Dean Joly
    Dean Joly Jan 16, 2008
    That is the best bet, you need to find out exactly where the leading edge of the paper is catching.
Error 22 paper jam
Check the fuser exit sensor flag. The sensor is on a p.c. board on the bottom of the fuser. Three things happen to it. Sometimes the board comes out of its clips and drops away from the sensor arm. The arm itself can be stuck or broken. The ribbon cable going to the board can come loose. If you release the latches and move the front cover out a little, it will be easier to get in to the board and cable.
Feb 27, 2012 | Lexmark Optra Lx+ Laser Printer
Lexmark optra s1855 paper keeps jamming
check this site http://www.ehow.com/how_5326976_fix-carriage-jam-printer.html
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. thanks
Aug 17, 2010 | Lexmark Optra S 2455 Laser Printer
Consistently get a paper jam error when I go to print on my Lexmark OptraC710
sounds like you need to clean the feed rollers that feed paper into machine with clean rag and isopropyl alcohol (rubbing alcohol) and/or looking for any paper jammed in machine...
Dec 27, 2009 | Lexmark Optra C710 Laser Printer
Stuck on 202 paper jam error message. there is no paper jam. Tried unplugging but message still persists
check the paper switches, there is one in the front under the cartridge and another one in the fuser unit.
Oct 23, 2009 | Lexmark Optra S 1255 Laser Printer
Lexmark C710 MFP jams 200.04
Things to try:
1. Look for a piece of paper jammed in the rollers. 95% of the time that is what it is.
2. You have a paperclip or paper wad in a feed roller or gear.
3. The hard and easy way to find the jam is to feed a piece of paper and then before it feeds all the way through unplug power to the machine about the time where it usually jams.(several times may be necessary) Then follow the piece of paper to where it jams to find the location of the clogged paper.
Sep 15, 2009 | Lexmark Optra C710 Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Aug 23, 2007 | Lexmark Optra T610 Laser Printer
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Lexmark Optra C710 Laser Printer Logo
184 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
