Question about Dryers
Dryer problem The machine will start and run for maybe five minutes and then shut off. After 20 minutes it will start again and run for 5 minutes and shut off. Where to look? What to check? Already check venting ( no obstructions ), thermostats ( all check good ), motor leads ( check good - under no load ) What now ?
  • 25 Answers
What you're describing sounds like the "wrinkle free" function of the timer. If it's happening at the end of a dry cycle, this is perfectly normal. If it's happening at the start of a dry cycle, then the timer is broken and will need replaced.
Posted on Jan 10, 2008
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Runs for 4-5 minutes shuts off. Beat on door and it runs for 4-5 minutes and then won't run for about 20 minutes. Is it the door switch?
Hello
Try taking the door switch out and tieing the wires toghther with a wire nut.UNPLUG DRYER FIRST.
If dryer runs ok then its the door switch.If not then its possible the motor is heating up,you can clean the lint and dust off the motor with a vacum cleaner by taking off the rear panel or turning machine on its side.
Apr 06, 2011 | Amana LEA11 Dryer
Sometimes my dryer will shut off 5 min after I start it then when I try to turn on again notheing I have to wait for a minute then it will let me turn on. Then sometimes it will shut off maybe 15 or 20...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 30, 2010 | Crosley Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Dryer runs for 20 minutes. shuts down. won't start again for 2 hours.
Hi, It sounds like you have a motor going bad. If this is a whirlpool brand models, the motor is about $90.00 to $100.00. If I can assist you further, please let me know.
Thanks
Vic
May 21, 2009 | Dryers
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Blinking error codes?
Unplug the machine for 30 minutes , plug it back it, start it for 1 minute, unplug it again for 5 minutes then plug back it and it should work. If not then write back with the error codes so further diagnostics can be done
Apr 08, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
Marvin
Marvin
