Question about One For All Televison & Video
One for all tv link sv-9736 setup. does the tv link go directly into 2nd tv or tv link into coax the tv?
Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Jun 04, 2014 | Proscan Televison & Video
Proscan how to
I have a Proscan Flat Screen TV Model PLEDV2845A. I want to connect my Philips HTL2101A Sound Bar.
I have intially connected both via Coax cable as the soundbar does NOT have HDMI port. I then went into the setup on the TV to Sound, set sound to PCM
Initially it worked fine. 2nd day it will not won't work. Per instructions from Philips I have upgraded the firmware on the SoundBar.
Any ideas
Jan 06, 2014 | Proscan Televison & Video
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
Sv 2000 tv
0038,0031,0033,0036. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 18, 2013 | RCA Universal Remote Control
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Nov 01, 2009 | Panasonic Viera TH-42PX80U Plasma TV
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
I can not get a TV signal to work with the Toshiba through coax.
bill24 sorry to be the one to tell ya but you need to go into setup on the tv to setup the channels in the menu and the memory and the only way is to do it with an original remote. BUT your in LUCK. http://remotes.com or 1-800- remotes has the remote you need for $27.38 + shipping. Good Luck
May 27, 2006 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Televison & Video Logo
319 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
