Question about Philips ProScreen 4750 Impact Multimedia Projector
It keeps overheating.
The project will be on for about five or ten minutes, then turns the lamp off and flashes the lamp button
Is the fan set to run continuously? Go to the menu and see if it's set up to run. Also we have this problem with mounted projectors in our classrooms, we have to keep the room cool, and make sure the projector gets circulation of air.
Hope this helps.
Posted on Nov 18, 2009
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Shutting off and turn back on ever five to ten minutes
Did you replaced lamp in Hitachi 60VX500 tv in last 2-3 years?
If not then it is time to replace lamp to solve tv issue.
Let me know if you have additional question.
Thanks.
Nov 28, 2010 | Hitachi 60VX500 60" Rear Projection HDTV
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
Turn off
I think you recently replaced lamp or opened lamp cover which is not installed properly.
Please check Lamp Cover because 3 times error shows that lamp cover is not fixed.
Feb 19, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
RCA HD61LPW175 will not turn on
Replace the Lamp if you have played it over 5000 hrs.
Feb 16, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Projection lamp indicators
maybe you have lost contact at the lamp circuit! check the CRT circuit and the lamp circuit!
Oct 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Philips ProScreen 4750 Impact Multimedia Projector Logo
203 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
