Question about Sylvania Televison & Video
VCR is displaying snow on the screen and static. Cannot play a tape
  • 45 Answers
Your unit is dirty and will need to be cleaned by a cleaning tape, available at any retail store or electronics specialty store. Also check the internal compartments to make sure nothing is loose, broken, or misaligned. If these do not work then the unit needs professional repair or replacement. Good luck to you!
Posted on Dec 13, 2009
I have the remote the date etc. programmed OK but how do I set up the actual recorder with undefined
Panasonic are very good at having free PDF copies of user manuals. However if you just want to playback old tapes then all you need do is connect the vcr to a TV and press play. You might need to adjust the tracking using the controls on the remote. But the picture should play. If you see snow on the screen, but can hear sound, then the tape heads will need to be cleaned. You can get a VCR cleaning tape for that.
Oct 29, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a Mitsubishi HS-U448 VCR. It plays my VHS tapes fine, but I can't get a blue screen when I turn it on. When I press 'play', the movie looks great. Once I hit 'stop', it'
It sounds like it is set to a TV station and since all the analogue stations have now gone you will only get static. Without a remote you wan't be able to switch it. I suggest you either shop around for a replacement (try Curry's partmaster) or use a universal one.
Jan 16, 2013 | Mitsubishi HS-U448 VCR
Sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
Oct 15, 2012 | Sharp 13VT-N100 Combo
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Movie tapes have snow but not home video tapes can i fix it my self
I assume you have had this player a while and I assume that all the programs that work without snow are ones that you recorded using that VCR to do it. Right?
If so, it is a compatibility issue where the last time you had it fixed, the repair guy did not check for VCR to VCR compatibility. I had a shop for 15 years and this is common.
Do you have a Tracking control? try adjusting that. It is either a physical control or part of the menu, depending on that specific model.
Last...last is to open the unit and you must be very very careful. Put in a tape that is from another player that plays snow and identify the shinny rotating head if you can physically see it. It sits at an angle and the RCA is typically in the back middle, about an inch in a half in diameter. While playing press your finger very very lightly in the middle of the shinny exposed video tape for like 4-10 seconds and maybe the snow will go away.
Your video head may be worn or dirty. Do not attempt to clean the heads the are verrrry delicate.
3. Try finding an old VCR cleaning tape. It does the same thing as your finger.
E
Mar 01, 2009 | RCA VR349 VHS VCR
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
27" Zenith Television
Assuming the picture tube lights up and you have snow when selecting the tuner function, I would first hook up a working VCR with a good tape and play it while the set is on channel 3 (if that is what your VCR is set to). If no sound or picture is displayed while the tape is playing,it could indicate a defective tuner. If you don't even get snow with no antenna connected (unless your set is designed to go to a blue screen with no signal present) then you could have a problem in the video processing circuits which would explain no picture with the RCA connections as well. This would probably make the set beyone economical repair.
Sep 15, 2008 | Zenith C27A24T 27" TV
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Small TV/VCR Combo
Have you tried using a VCR VHS cleaning tape? Looks like a movie tape but its actually a head cleaner. You might have to try that several times.
Apr 27, 2007 | Kenmore 22642 Top Load Washer
Televison & Video Logo
46 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
