Where can I find repair parts for aspire 9410z? i dropped my laptop and it landed on the side where the power adapter is connected. The internal pin broke off inside the adapter.
  • 863 Answers
Type your model name along with the words parts repair on e-bay search.
Posted on Nov 18, 2009
What are the Schamatics to a Dell ac/dc adapter MODEL: DA90PS1-00
Specification of DA90PS1-00 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W MaxOutlet: 3-Prong
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Sep 18, 2011 | Dell Laptop DC Power Jack (DELLDL271600)...
I have an Acer Aspire One and when I plug the charger in I have to spin it or wiggle it or both to get the battery to charge. Once I have it in position it generally stays on charge, but if the cable is...
It could be either one Sarah.
The AC adapter's (Charger) cable, or the DC Power Jack where the AC adapter plugs into the laptop.
This is an example of the DC Power Jack not installed,
http://www.laptopjacks.com/view_part/Acer-Aspire-ONE-AOA150-ZG5-DC-Power-Jack-AC351816.html
(You can click on the three views of the jack to enlarge)
1) Check the DC Power Jack to see if it's in good repair.
Battery removed use a small flat tipped screwdriver, and Gently see if you can move the Center Pin around in the jack.
See if the Center Pin will move side to side a small amount. There is supposed to be No perceptible movement.
Referring back to the closeup photos of the DC Power Jack, the flat blade-like prongs are upside down, in relation to how the jack sits on the motherboard.
The flat prongs go down through the motherboard, and are soldered to the motherboard.
If the center pin of the jack is stationary, but the jack as a unit moves around, one or more solder joints, (Connections) for the flat prongs may be cracked.
The repair consists of completely disassembling the laptop, removing the broken DC Power Jack, and installing a new one.
Acer Aspire One service manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
(Click on the blue - One - in Aspire One.
This is a PDF file. The computer you are using now has Adobe Reader on it which uses PDF files.
After you click on the file name (One) it may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
(Took 12 seconds just now for full download)
No perceptible movement of the DC Power Jack? Suspect the cable of the AC adapter right near it's plug. (Plug that plugs into the DC Power Jack)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 25, 2011 | Computers & Internet
Acer Aspire 9410z Wont turn on. Ive checked hard drive, ram, and charger and all work but just wont turn on
likeley you have problems with th4e motherboard or the system power board, or even the laptop power switch. try taking out the battery and try to turn it on, if it powers up then it's a battery issue, otherwise you need to have a repair center look at it.
May 26, 2011 | Computers & Internet
Orbicam does not work on my aspire 9410z with
Hello
mine does!
install the divece driver for vista
go into install map
try the exe
make shortcut on your desktop.
that will do.
greets
Luuk Sollie
Jan 27, 2010 | Acer Aspire 9410 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Can not power up ACER 9410Z laptop after replacing memory
Try to remove one and restart with just one installed,if it restarts,Let it completely load,shut down and reinstall the other one and restart again.
May 31, 2009 | Acer Aspire 3000 Notebook
No DC Power To Laptop
The problem is the input power socket on the laptop. It is either damaged, or the soldered connections on the connector has disconnected from the motherboard (eg formed a dryjoint).
It should not be too expensive to repair, or you can pull apart the laptop yourself and resolder the power connections. I suggest you use a temperature controlled soldering iron and ground yourself with a static strap for this repair.
Jan 07, 2009 | HP Pavilion dv6000z Notebook
Aspire One NO turn on at all
You need a DC Jack Repair/Replacement..
your dc jack is the port where your AC Charger plug plugs in to on the laptop.. They can Short out over time and the solder that connects the positive/negative pins burns off which causes the power to short out ... which in turn cuts off power connection to the laptop and can cause motherboard damage if not repaired..
Nov 27, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Acer aspire 5610 internal blue tooth connection
Turn the laptop upside down, its one of the covers that is openable with a normal + screwdriver. One of them has the memory other has hard drive and the 3rd should have the addon cards.
Id have to find a service manual to confirm this. But this is how it is in most acer laptops and I have repaired a few.
Apr 05, 2008 | Acer Aspire 5610-4648 Notebook
Televison & Video Logo
Top Televison & Video Experts
