Question about Memorex Televison & Video
Hit the default on my Memorex 9624M DVD
We werent getting the surround sound, so we hit the default on my Memorex 9624M DVD player (its on a RV) and now i get sound, but no pictures...
Is there a reset?? or could it be Progressive scan??...the thing is i can
even get into a menu to fix the problem...
But thats the only thing we did was hit the default setting on the remote, didnt touch anything else...
thanks for any info
SOURCE: insignia dvd/vcr combo progressive scan mode
thanks worked great
Posted on Aug 05, 2007
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Sure that's easy, I read this in the manual:
http://tacpservice.toshiba.com/ConsumerProductSupport/Manual/dvd/SDK530.pdf
(Page 18 - Progressive Scan Section)
All you have to do is:
1. Remove the disc in the DVD/VCR.
2. Press and hold the STOP button for 5 seconds before releasing it. (Note that this is the stop button which is physically on the player.)
And that should pull you out of Progressive Scan Mode.
Posted on Nov 06, 2007
SOURCE: progressive scan
Open the drive and hold down one on the remote...
Hope you still have the remote!!!
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=US&session=20071221020919_75.82.190.84&slg=AEN&refnr=0016098&refdisplay=AVS_DVP_011&dct=QAC&ctn=DVD622/37B
Posted on Dec 21, 2007
SOURCE: Progressive Scan
On 12/29/2007 at 1135pm, I found the solution for yours and my problem. Here is what you need to do. I did the same thing and couldnt get video. If you set Progressive Scan to ON in error , you must reset the unit. Play your dvd, then press "STOP" to stop the disc from playing. Hold the stop button on the dvd player for approx 5 seconds before releasing it. The video output will be restored to the standard setting, and a picture will once again be visible on a conventional analog TV or monitor.
Posted on Dec 30, 2007
SOURCE: Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Posted on Mar 29, 2008
How do i hookup my memorex dvd player mvd2047 to my dish box to watch movies
I have a Philiphs DFR _1600 Surround Sound Receiver with Built in DVD Player . I Don't Have The Remote , I got the Dfr 1600
ay Gooodwill for $25 Dollars ,
I would like to ADJ The rear Speakers , Turn them up
Is There a Way to turn up the Rear Speakers on the Unit it,s Self .
with out a Remote .
My Kenwood Surround sound Unit has this on the front of the unit .
Thank you
Harry w
Dec 04, 2013 | Televison & Video
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
I have a Memorex MVD2042 DVD Player and trying to hook the dvd player to my surround sound, the receiver on my surround sound has 6 rca hookups for each speaker for the dvd player. But as far as I know the...
There is only 2 audio channels on player (L&R) Is there any audio input jacks for just the red and white (L&R) connections. Or just for main speakers?
Nov 19, 2009 | Memorex MVD2042 DVD Player
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Need user guide
I bought a used RV as well, and while the manual was not included, we were lucky enough to have the original "90 Day Limited Warranty Card", which provided a toll free number to the Customer Service Department. I called and a copy of the manual is in the mail to me today. 1-800-982-3954, ext 117. Good Luck!
Sep 22, 2008 | Audio Players & Recorders
No sound out of surround back speakers
It sounds like you don't have your surround sound source set up properly (your DVD player is not set up for PCM sound).
the best quality audio will be to set up either digital or optical audio between the DVD and the receiver.
Once you have connected the optical or digital audio cable between the DVD and receiver, you have to go into the DVD player audio setup and change it to PCM digital audio or you will not get surround sound. DVD players are not set up by default to output surround sound.
Sep 05, 2008 | Yamaha RX-Z9 Receiver
Memorex DVD player problem
Hit the PSCAN switch on the back of the unit.
Aug 09, 2008 | Memorex MVD2042 DVD Player
Televison & Video Logo
212 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
