Question about Konica Minolta Bizhub-200 Minolta Printer
Lines on pages when copied - Konica Minolta Bizhub-200 Minolta Printer
  • Konica Minolta Expert
  • 158 Answers
Lift the document feeder on the machine and there is a small glass about 1.5 inches wide to the left of the big glass clean it with alcohol and try to make a copy to see if the line has gone away if not you will probably need to get the drum and developer unit replaced or the fuser unit replaced.
Posted on Nov 20, 2009
Copy issue with a line from top to bottom
if printing is fine and copying causes line on page, I suspect that there is dirt on the scanner glass. Clean scanner glass.
Apr 01, 2010 | HP LaserJet 3050 All-In-One Printer
Printed pages come out with dark lines under each line of print
Find your printer's "Maintenance" menu, in its "Toolbox" or from the Start Menu.
Preform a cartridge or head cleaning, that should solve your issue. If not, try replacing the cartridges with new ones.
Hope I helped,
Tom
Jun 21, 2009 | HP Photosmart C5280 Printer
Lines appear on each side of page when I copy
Open the document feeder and clean the scanner glass.
Feb 21, 2009 | HP Officejet 5610 All-In-One InkJet...
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Thin black line on Xerox 4011 laser printer
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Nov 21, 2008 | Computers & Internet
Line on paper after page prints
This seems to be a common theme. I just posted a response to someone here with a similar problem. HP.com has a web page that can help you go through a series of diagnostic tasks designed to track down this problem:
Streaks or Lines in the Printed Page
There's also a help page that talks about lines on pages when you use the Copy feature. Not quite your problem, but it may help:
White Lines Through Copies
Hope some of this helps. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Copier problem
HP.com has a few web pages that might help. One is a general troubleshooting page that you can review and the other specifically addresses the issue of "white lines" in a copy:
Troubleshooting Copying Issues
Read through both web pages and see if there's a suggestion that will help solve your problem. Good luck.
Aug 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
133 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
