Question about Sony DSR-45P DV / Mini DV VCR
Sony DSR-45 open/closed is filed when push eject
  • 29 Answers
Front door assembly rotary( a motor assembly) may be faulty if it is trying to close and open but not completing. one micro fuse may be blown if it is not at all trying to open and close.
Posted on Jan 23, 2010
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Jun 27, 2013 | Sony DSR-45 Mini DV VCR
My DSR 45 Firewire port is fried. Any idea which Problem with the Sony DSR-45 Mini DV VCR
DSR-45's firewire port is held on a separate littlle circuit board, easily reached from the underside of the deck. Remove the bottom panel, unplug the cable from the Firewire board and there is 1 screw to hold the firewire board in place. The part is called DV-032 on Sony's Parts website and costs about £30 UK including postage to buy.
Sep 16, 2011 | Sony DSR-45 Mini DV VCR
My dsr-45 no eject cassete
please follow this :-Remove the case, remove the mechanism cover, cut the mangled tape in pieces and take it out gently - you are going to have to rotate some part to untangle most of it. With all the tape that's out of the cassette removed from the mechanism put the unit back together and eject it.
i hope this will be helpfull to you .
goodluck.......
Feb 02, 2011 | Sony DSR-45 Mini DV VCR
Connected by DV Jack. MacbookPro not seeing it
try reseting the dv deck to factory settings then open quicktime in your macbook go to file the go down to new movie recording then on the errow that is pointing down select sony DSR-45
Aug 07, 2010 | Sony DSR-45 Mini DV VCR
Our sony dsr 45 is giving us a C:31:41 Error code shortly after tape is inserted.
error cause by drum head, u can try fix by ur self, open the compart then open the black drumhead cap,u can see to screw on the upper head open,then u can see rubber pick it up clean the rubber and the con inside outside head, try again if doesn't work u can change the drum head
Nov 30, 2009 | Sony DSR-45 Mini DV VCR
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Sony DSR-45 will not eject tape nor play,ff,rewind shows error
The generic error codes C32:xx indicate that a motor is not functioning. If you have not worked on these machines before, extreme caution is advised. These have extremely sensitive alignments that can easily be disturbed.
Please update this with your familiarity with these machines and I'll try to provide additional directions.
Thanks,
Dan
Nov 21, 2008 | Sony DSR-45 Mini DV VCR
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Aug 07, 2008 | Sony DSR-45 Mini DV VCR
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
Synchronize the DSR-45 as a 'slave' to an external unit with SMPTE Timecode
if i,m not miss understanding the problem is rec audio ng.if it,s, the posible cause are; 1;head dirty at the line of the tape causing data from head can,t write the tape optimal.for this problem you can clean the head carefull the head can easy broke., 2;if the picture having tracking posible the guide that bring the tape at the left doesn't fully at the track.for this problem at emergency you can try to push the left guide.
Sep 19, 2007 | Sony DSR-45 Mini DV VCR
Televison & Video Logo
139 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
