Question about IBM PC 300PL PC Desktop
I'm getting power to the motherboard,but not getting any bios at all,so i cant install an operating system IBM PC 300PL (656586U) PC Desktop, any suggestions?
  • 128 Answers
Read up on it first then do exactly what they say.,....
Posted on Nov 18, 2009
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
I can't remember the username and password to logonto my ibm pc 300pl desktop pc. It's been years since I used it and I now need to get onto it to get some files off it. Can anyone advise what I can do?
If it is a password that is needed before windows OS boots, try the following.
Power off the computer, unplug the power cord (also any seperately powered devices connected to the computer. Open case; you will see a silver button battery with a diameter close to that of a nickel (BIOS battery). Note the direction the battery is oriented (positive side/negative side). Plug in computer and restart. After 30 seconds, shut down computer again, unplug power supply, reinsert battery same way it was originally oriented. Put computer case cover on, plug in computer, restart computer. No password will be required.
Apr 12, 2010 | IBM PC 300PL PC Desktop
When i start my 300pl desk top system. when i
Hello my friend.That error message has nothing to do with the actual keyboard.The POST/BIOS is reading a single port bit in the system boards keyboard controller and detecting this bit as being shorted to ground. On some systems there is a keylock on the front of the case that allows you to "lock" the keyboard for security reasons. It is this lock that is being detected. On a system without a keylock, this error can be caused by one of the front panel wires being placed on the wrong pin on the system board. Or by something shorting out the keylock pin on the system board, or a hardware failure in the keyboard controller, or using the wrong version of BIOS.So make sure if your computer has a lock key/button or something on the case that locks the keyboard.Also you can load default bios settings by hitting Del while you boot if you have change anything in the bios.
Feb 08, 2010 | IBM 300PL (PC 300 PL 733) PC Desktop
Asset antenna not detected
go to the bios setup by pressing F1 or as require by the system and check for security and disable any and save it
Dec 18, 2009 | IBM 300PL (PC 300 PL 733) PC Desktop
How to boot via CD-ROM in IBM PC 300
my IBM flat desktop is not booting from CD ROM, Please help me.
Jun 18, 2009 | IBM 300PL (PC 300 PL 733) PC Desktop
BIOS BIN Files
I think Ur pc is ibm ok then go to the website and download for ur product bios and install .
ur in operating system download as exe file (or) download as iso image and then bootable for the bios in ibm.
http://www.ibm.com/support/in/en/
Check the site.
Feb 02, 2009 | IBM NetVista PC Desktop
Problem with my ibm300PL BIOS
nvjt58a.exe 1,050,983 Flash BIOS update
nvjt58a.txt 17,012 README for the Flash BIOS update
Oct 29, 2008 | IBM 300PL (PC 300 PL 733) PC Desktop
CMOS BATTERY
It really depends on the Driver model.
On the latest models capicitors of BIOS can hold the charge for longer and you can easily change the battery with the new one.
If you have the old board just go ahead and change the battery as usual and dont worry for the settings at all.
You can load the safest default settings by pressings F1,F9,F10
Jun 01, 2008 | IBM PC 300PL PC Desktop
My 500mz IBM 300pl computer is giving me this masage i cant tart the computer
Install a new CMOS battery. Go to walgreens, walmart, something and buy a new one. This is located on the motherboard. Following this, you may need to flash the bios, and reinstall with a newer updated version.
May 29, 2007 | IBM 11L1619 Motherboard
I B M 300pl mother board boot problem
Yes you will not be abble to do anything until you remove the protection code which someone activate it. Try to remove the battery on the motherboard and then boot the computer.
May 23, 2007 | IBM 11L1619 Motherboard
IBM PC 300PL PC Desktop Logo
76 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
