Question about SMC Realtek 10/100TX PCI Fast Ethernet Card (NICPCI) Network Adapter
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without problems. Router working fine to other computers. Cable modem working fine. I'm stuck. Keith
    President:
  • 1,015 Answers
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Posted on Nov 18, 2009
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
My acer 4310 connects fast to wi-fi pero pag internet cable na as in ung dsl hindi gumagana
When you plugged in the ethernet cable, does it show on your windows tray (lower right corner of the screen) that the LAN is connected? It should show you "Connected" if you hover your mouse on the LAN icon.
Try also to plug in the ethernet cable to a different port on the router, and that the port number on the router is showing a solid green led light.
If all has been observed and still you cannot connect, look if the network adapter for your lan is working. RIGHT click your My Computer or "Computer" and select Manage. The Computer Management window will open. Click on the Device Manager on the left to show the list of devices on the right. Look for Network Adapters and click the + sign. See if your LAN adapter is not showing any yellow exclamation point. Also, right click on it and select Properties. You should see the device is working properly under status.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Acer Aspire 4315 Notebook
I have Windows 7 Build 7600. My Gateway NV5814 laptop doesn't connect to the internate post a windows update. The Ethernet cable is plugged into the NIC port but the blue and green lights do not blink and...
hi
Please disable windows update. Click on start , click on run type services.msc and click ok locate windows update , double click on it , click on stop and change the startup type as disabled . Click on apply and reboot .
Nov 18, 2010 | Gateway Computers & Internet
Ethernet connection fails to cable modem
Let's do a little bit of troubleshooting and see what we find out. First I assume that you are using some kind of Microsoft operating system. (if not, let me know.)
  1. You say that the cable is working fine. That's a good start.
  2. If you connect your cable to the GX, do you see an orange (connectivity) and a green (traffic) light next to the adapter?
  3. Did you check your Device Manager to see if the adapter is working? (Right-click "My Computer", choose "Manage" and open "Device Manager".You should have an entry under "Network Adapters". The on-board, standard network card is an Intel Pro/1000MT.
  4. If there is no entry, then the adapter is faulty (or not recognized by the Operating System).
  5. If you have an entry - is there a yellow question mark? If so, then the driver is missing. You can download it from Dell's support page here.
  6. If your adapter is broken, you can always try to find either an external USB-to-Ethernet or wireless USB adapter or install a new network card. See example here. Make sure that you get one that also comes with a small installation frame, so it fits your housing. (look at the pics in the link.)
  7. If your network card is fine and you have a driver already installed, it could be your network settings. Is your adapter set to get an IP via DHCP? Open your Control Panel and Network Connections. Do you see an entry there? If so, right-click it and choose "Properties". Scroll down to "Internet Protocol TCP/IP" and double-click it. Are both radio buttons set to "Obtain...automatically"? If not, change that and click "OK" to close all related windows.
If you have any more questions or need more help with any of the steps above, just come back here and leave a comment - I'm happy to help.
Aug 02, 2010 | Dell Ethernet Card Network Adapter
Hi, My Wireless adapter -Belkin 802.11b is stopped working all of a sudden. There used to be a green light on the adapter when it is plugged in to my laptop, now there is no light. My Dell Latitude...
First check whether the adapter is working or not?
In the device manager you are able to detect the adapter, that is a good sign.
When you go to the adapters properties, does it say working properly,
If it is , then you just need to connect to the wireless network and the light will lit up
Click Here for more info
Oct 06, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Cannot get on the internet
light should be green instead of orange. check in your device manager to make sure the driver is installed for the ethernet adapter, if it is then you know the motherboard is bad cause the ethernet adapter is connected to the motherboard.
If the driver for the ethernet adapter is not installed then go to support.dell.com and from there go into the drivers section, type in your model and then download the driver for your laptop and install it and then see if you can connect. If you do this and you still can't connect then that still means the ethernet adapter is bad and the motherboard would still have to be replaced.
Aug 09, 2009 | Dell Inspiron B120 B130 1300 / Latitude...
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
When I connect the wrt160n in the pc it says network cable unplug
Check the Ethernet adapter status under network adapters in devicemanager.
right click my computer-properties-hardware tab-device manager-network adapter.etherrnet should be green
Jul 12, 2009 | Linksys WRT160N Wireless Router
ASUSEee pc 900
Have you checked your ethernet connection device? Is there a green light blinking from where you plug the cable into your computer? Do your have an on board device or an ethernet/wireless card?
What error messages (if any) are you getting?
Go to device manager in system properties ( logo + pause/ general tab/ hardware/ device manager) a quick short cut, and check to see if your have yellow exclamation mark or red x in "network adapters". Make sure your device is listed. If you see it right click/ properties/ under device status see if it is enabled and working. If not click to enable it.
Maybe a little more info on your problem like is there an icon on taskbar (bottom right by the time) that shows a monitor icon with/without an X on it?
You might have to run the internet connection wizard. If all fails try opening the case & removing the card (if thats what you use) and re seating it. Turn pc on & look for a "found new hardware" balloon on bottom right/ follow instructionsl.
Sorry for all the questions but this should leave you with 1 or 2 other options anyway.
Oct 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Networking Problem
It is not uncommon for the network adapter to become faulty and stop working. Since you've checked the cable and it is still listed in device manager as working properly, I would add a PCI ethernet port to your computer, then disable the faulty one in device manager. They can be picked up for around $15 locally and even cheaper on the web.
Jun 14, 2008 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
176 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
