Question about Crosley Washing Machines
I have the CFW-8000 washing machine. When the
I have the CFW-8000 washing machine. When the timer states 1:09 is this 1 hours and nine minutes or 109 minutes. I noticed that my washing machine takes a long time to wash, so I set a timer. The 1:09 that the machine stated took an hour and 43 minutes to wash. Also, what would cause the liquid soap dispenser to fill with water, after the washer has stopped and the softener dispenser to not dispense. I have noticed that after opening the container for a new load and closing it that the liquid drains out of the container, onto the front of the machine and pools in the handle of the drawer.
    Scholar:
  • 53 Answers
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Posted on Nov 18, 2009
Fisher and Paykel washing machine
Without being smart...buy a new machine. It sounds as though the timer is dying...therefore slowing down...therefore extending cycle times. If that's the case, a new timer will cost about half the cost of a new machine.
May 06, 2012 | Fisher and Paykel Washing Machines
Tip
Dyson Hot + Cool AM09 fan heater - Getting started
How to assemble and use your new Dyson AM09 Hot + Cool fan heater. Adjust the power and oscillation, choose between diffused or focused modes, set the target temperature and sleep timer, and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Nov 27, 2014 | Dyson Dryers
Tip
Dyson Cool AM08 Air Multiplier pedestal fan - Getting started
How to assemble and use your new Dyson Cool AM08 Air Multiplier pedestal fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 | Dyson Dryers
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
Oct 01, 2011 | Hardware & Accessories
The manual timer in the picture has 120 minutes on it . the discription says it's a 240 minute timer. what is it?
Timer is not identified.
Add a comment with in-focus photo of timer posted on flickr, or describe all details about the timer for possible help.
240 minute timer could be a cycle timer that repeats timing cycle each 4 hours.
Tork 8000 series cycle timers have 6 minute to 1 hour
Intermatic cycle timers range from 10 minutes to 4 hours
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/specialty%20time%20switches/c8800%20short%20range%20cycle%20timers.aspx
Adjustable cycle timers, percentage cycle timers have variable time settings that span 1 to 24 hours.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#JW
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=cycle+timer&op=search&Ntt=cycle+timer&N=0&sst=subset
Jul 18, 2011 | Hardware & Accessories
Tip
Dyson Cool AM07 Air Multiplier tower fan - Getting started
How to assemble and use your new Dyson Cool AM07 Air Multiplier tower fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
Tip
Dyson Cool AM06 Air Multiplier desk fan - Getting started
How to assemble and use your new Dyson Cool AM06 Air Multiplier desk fan: adjust the power and oscillation, change the angle of the loop, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
How to set times
You posted under Tork 8000 series cycling timer
Open following link to identify timer for sure and download wiring and instruction manuals.
Cycling timers have built-in trippers (or tabs) located on outer edge of dial
Lift each tripper up and rotate it toward center of dial to set on-off times.
The dial rotates as time passes, and the trippers move lever that turns load on-off.
For example if you have 8601 timer, the dial cycles every 60 minutes or once per hour.
Each tripper represents 1 minute.
So if you want NO terminals turned ON for 2 minutes each hour, then move 2 successive trippers up.
If you want NC terminals turned ON for 58 minutes, then leave 58 successive trippers down.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | TORK Variable Cycling Timer 8601
Lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
Delay Wash
must be only 9 hour timer in this model
Oct 30, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
269 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
