Question about Campbell Hausfeld No.FP2028 Gal Pancake Compressor
I need motor brushes for model# H1506FWH Husky 1.5 HP pancake compressor.Where do I get in the Mobile, AL area?
  • Anonymous Mar 15, 2014
    i need a brush holder for a husky air compressor model h1506fwh
  • 530 Answers
First you have to understand something important about motor brushes. That is the only difference between all motor brushes is their size (brush diameter and contact wire length). This includes fan motor brushes, water pump motors, power tool motors even automobile alternator brushes.
You can also find brushes where you might not think to look.
If you can get even close to the same size as the old set you can file the new ones down to fit. I've done it time and time again.
Your best bet is automotive electronic stores. However you might find them at local auto parts stores, hardware stores like Home Depot (look in the section where they have all the small parts bins). You might also try Tractor Supply. I know they are in Alabama but not sure if there is one close to you.
Remember you can modify the length of the wire also. If the old set has a small contact point on the end of the wire just remove it and solder it to the new brush wire.
I hope this helps you out.
Posted on Nov 22, 2009
Found the brushes on ebay. I'm not advertising, but these brushes look to measure up. The measurements are 25/32"x7/16"x1/4" http://cgi.ebay.com/25-32-x-7-16-x-1-4-Electric-Motor-Carbon-Brushes-New-/320730966356?pt=LH_DefaultDomain_0&hash=item4aad0e2954#ht_1988wt_1347
Posted on Aug 10, 2011
  • n3lka Aug 10, 2011
    I was searching for the same brushes for the same compressor I found in the trash.
Husky pancake compressor won't fill
have you checked the ring and cylider or the valves?
Jan 02, 2013 | Stanley FactoryReconditioned Bostitch...
How do you get the outer plastic top off a husky h1506fwh compressor
There are 4 allen head screws pointing down from the top that hold it on.
http://www.mastertoolrepair.com/images/H1506F_tank.jpg?osCsid=3mslptdrcjeuae0kji3n7qs7g3
This image also shows some screws up from the bottom, but I am not sure.
Feb 26, 2011 | Air Tools & Compressors
Im trying to find brushes for my electric motor in my husky air compressor mod# 417-270
I have not been able to find brushes for your type of compressor. I find a close match on ebay and shave/sand to size. Measure your brushes. Search ebay for "carbon brushes" looking for best price and size needed. Make sure that the armature is still good because the brushes will wear very fast if arm. is bad. Good luck
Feb 13, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have an H1506FWH Husky 6 gal 1.5 hp compressor that won't build air pressure. While running I noticed a change in the sound but it kept running. However, I no longer had much pressure. Now I can't get...
Locate the piston housing and remove the outer plate 4 screws
then tap on the next plate and when you remove it ( its the reed plate) you will most likely see a hole in one or more of the reeds
I am not technical but I have the same peoblem and I am trying to replace the reed plate on mine when I saw this. Good luck
Nov 22, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Husky pancake runs in reverse
I am a little confused here ... I have a Craftsman pancake, a Craftsman 6 hp (same compressor design) and several other name brand pancake compressors at the job. The compressor doesn't care which way the motor runs though mine all run in the same direction. As long as the piston goes up and down, the reed valves know when to open and when to closed based on the pressure. It sucks in from the 'room' on the down stroke and blows into the tank on the upstroke.
Yours isn't doing this? If it is creating a vacuum in the tank, I would have to say someone put the valves in upside down.
This is very curious.
You could reverse the black and white wire but as I understand the physics of it, it will not matter where the hot wire is since it is AC. The motor may be reversable but I'm thinking it is probably not in this case. That costs extra to make into the motor.
Please inspect the valves to make sure they are capable of 'inhaling' (the site will delete the other word I used) on the down stroke and 'exhaling' into the tank on the upstroke.
Please let me know what you find out.
Thanks for your curious question at FixYa.com
Jan 15, 2010 | Air Tools & Compressors
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Got a Husky 6 gal pancake, 1.5hp. motor runs- no air pressure ??
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Piston snaped on my husky 1.7 hp 32 gallon
I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try Northerntools.com.
May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Campbell Hausfeld No.FP2028 Gal Pancake Compressor Logo
1,433 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
