Question about LG WM-2277HW Front Load Washer
Te error on LG frontload washer
Te error on my LG frontload washer. Any suggestions before I call for service?
  • 1 more comment
  • Bennis Jan 10, 2008
    No it's te. I found the service manual an it states te = The THERMISTOR is out order. I thought I would just check the connection first and then replace the part. Hoping that it is in fact a bad thermistor. Could it be something other than a bad thernistor?
  • Anonymous Mar 13, 2014
    lg te error
  • Anonymous Mar 26, 2014
    water does not fill in lg frontload washer model wm2016cw
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Posted on Jan 10, 2008
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
TE error LG2077 CW washer
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
TE error code problem How to fix the thermistor
Sep 27, 2011 | LG WM-2277HW Front Load Washer
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
Te error pops up washer stops clothes still in it already drained filter not that bad
the thermistor is busted te means thermistor error need service technician tough job
Jan 05, 2011 | LG WM-2277HW Front Load Washer
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
How I fix an error code on a LG wm2669hna washer that says TE error
May 17, 2010 | LG WM-2277HW Front Load Washer
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 29, 2009 | Washing Machines
LG Dishwasher LDF7810 SST : tE Error (thermal error?)
Recommend that you closely check the water temp of incoming water. There is an error in some service manuals and if the inlet water temp is greater than 149 degrees (F) (some manuals incorrectly say 194 degrees), you could get an imediate tE error.
If that does not solve the problem:
_recheck_ the electric resistance of Thermistor. (11~14k Ohms at 77 degrees (F) )
Good Luck!
Apr 01, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
LG WM-2277HW Front Load Washer Logo
1,110 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
