Question about 2wire (1000-400108-001) Router
Mine keeps going all red sometimes it has green powewr light and the rest are all red I have restarted many times even the computer at the same time nothing longer than a couple hours use at the most usually just works a little while?
    Brigadier General:
  • 10,406 Answers
Contact your ISP -- either they are having problems with all their customers in your area, or the 2WIRE router that they supply is "dying", and they should replace it.
Posted on Nov 18, 2009
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
May 07, 2010 | Sony Playstation 3 (PS3) Console
Hello, I have a sharp LC-37HV4U. I have red lights on TV and the box. I have tried to hold down "Input" and " - volume". This trick worked great and turned both unit power lights to green and tv would come...
turn the set on the way you have been once you set is on hit the down arrow and look on the menu for factory initiate
or reset right arrow to tun it on hit enter let the set do its thing and restart is see if that helps there is a problem with these where the controler errored out for what ever reason sometimes thr rest will fix your problem if not hten the lcd contoler will need to be replaced
Dec 07, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Turn on of unit sometimes does not light lamp. Red/Green flashing light, then turns on the next time. (Using button on unit) When using remote, can sometimes get it to turn on the first time (without going...
I'm having the same issue now. Did you ever figure out what was wrong with your unit? Was it a bad lamp? Mine is only 9 months old, low hours, but perhaps a bad one? Can't understand why it would light sometimes but not others.
Jul 01, 2009 | Mitsubishi HC5000 LCD Projector
Playstation 3 problem
Heat Sync issue. CPU and GPU need re-seating as well. Email dwdpcrepair@gmail.com for more help
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Console wont boot up
It's probably not dying. Just spend the time replacing the thermal paste on the heat sinks with Silver Thermal Paste from Radio Shack. Takes awhile, and you have to do it right. Don't be lazy and impatient with it while prepping the surfaces, and maybe it will all be alright. I switched out those 'X' clamps on mine with 4- 5mmX12mm machine screws, and 4 - 5mmX20mm machine screws...4 - #10 washers to even the mother board with the rest of the casing, A #10 Teflon washer on top of the motherboard(to keep it from shorting out in the future, and for heat expansion), another #10 metal washer on top of that, and then screwed them evenly into the heat sinks..Works fine now... Had to grind a few of the washers to have a flat side, and drill some 3/16 holes to make the casing holes a little bigger than factory size...but it was easy.
Jan 16, 2009 | Microsoft Xbox 360 Console
Modem keeps rebooting
This problem seems to be ISP based.. I'm having the same problems last 2 days with AT&T DSL
Jul 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Monitor keeps blank even the power lLED is on green
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Power switches off
Try changing refresh rate or resolution. You might be using one that your screen can't work with. good luck
Jun 09, 2006 | Philips 170C4FS 17" LCD Monitor
2wire (1000-400108-001) Router Logo
147 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
