I have a screen problem with my advent 9617 laptop the machine starts up but no display if i keep turning it off and on again it starts up fine and runs fine but when its turned off again it wont start i have tried a external monitor and still no display someone said it could be a screen inverter but im not so sure can anyone help please
  • 56 Answers
Goto computer shop
Posted on Nov 18, 2009
My laptop keeps switching itsself off
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 06, 2012 | Advent Computers & Internet
Screen on laptop advent 7102 very dull can hard use it hardly any brightness
The LCD screen for the Advent 7102 does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (Screen Inverter) converts electricity from the laptop, for the LCD screen, and the Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The Inverter is a small circuit board located behind the Display Bezel, and under the LCD screen.
[ The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame ]
Example of a screen Inverter for an Advent 7102 Netbook PC,
http://www.laptoppowerjacks.co.uk/category-27/Acer12.html
Regards,
joecoolvette
Oct 17, 2011 | Advent Netbook
Hi i had a wireless internet connection on my advent laptop till about 2 weeks ago and it doesn,t work anymore i have a internet conection as i,m using a different one and work perfect but this one...
Hi Friend, In this case as you have told me that you have other laptop which is working fine wirelesly. I would like you to check the IP address of the system in which you are facing the issues.
To check the IP address: 1) If system has XP Click on "Start" and then "Run". Type "cmd" in Run and hit enter A black screen will pop up, in that type "ipconfig", where the cursor will be blinking Check the IP adress under " Ethernet adapter local area connection" & " Wireless adapter"
2) If it is Vista/Win 7 Click on Start again and in Search field type cmd and hit enter Same black screen will pop up and repeat the same above steps in the black window and check the IP adress
Dec 07, 2010 | Computers & Internet
Advent black screen
This sounds like a bad video driver update.
Restart the machine and repeatedly tap the F8 key. When you see the advanced boot menu appear choose safe mode.
You will see white text on screen that will stop on a system 32 driver, wait a minute and let it boot through.
Next, go do device manager and uninstall the display drivers or roll back the driver to a previous one.
Reboot the machine and it should boot into windows normally. You may have to reinstall the display drivers if they don't reinstall themselves.
Please post back if you need anymore help or advice.
Good luck.
Jun 26, 2010 | Advent Netbook
My advent 9617 laptop has started switching of after aprox 1-2 minutes, this hapens in bios, and also whilst booting up windows
reset bios to the factory optimal defaults ..cause this is happening only when the max temperature point of the CPU is set too low and it is reaching it in a few minutes...and shut itself down ...
by getting to bios ..and look for the line when it says optimal factory defaults ...it will remove any settings and suspicions in this direction...after that press f10 to save settings and reboot...If the issue is still on ..check the cpu cooler cause it is dead and it is not cooling the cpu and this is shutting down as a protection .....
also check out if it is charging ok ...it may be the battery ..dieing in minutes..cause it is not keeping juice anymore..
Mar 22, 2010 | IBM Lenovo ThinkPad T61 Notebook
Year old advent netbook 4211b will not turn on,
When you press power button press F1 or F2 or "del" key if you can see bios screen then you not need to refix RAM memory or reset bios.
IF you can see bios screen then lake sure harddisk is detected and SATA is disable then save settings and exit.
Also when you power up press F8 key if you able to see safe mode and other menu then you have change screen resolution enter in enable vga mode.
Then open control panel and display then change scree resolution to 1024*768.
Then apply and ok.
But if you can't see bios screen or nothing in dispaly then you have to refix RAM memory .
Check in back side there is 1 plate open it then refix RAM memory.
If still not get display then open back cover of laptop then find motherbord on it then pull cmos cell for 10 minutes so all settings go to defaults then again refix cmos cell then check.
Let me know if you need more assistance.
Thanks.
Oct 08, 2009 | Advent Netbook
Troubleshooting IBM ThinkPad A31 monitor problem
The system is having problems with the graphics drivers, heres how to tell!!! when you first turn the machine on display is clear until it gets to windows. To resolve the problem is quite easy, just reboot into safe mode and un-install the graphics drivers, then reboot. When the system restarts is should re-install the graphics drivers automaticaly for you, job done :)
keep me informed please
regards
Nov 24, 2008 | Computers & Internet
Problems with advent 7113 backlight
i,d suggest trying the laptop on an external monitor firstly.
this will eliminate motherboard fault.
then if it displays fine on the external monitor.
possibility of Faulty Inverter Or CFL Tube.
Mike @ compurepair.
Jul 22, 2008 | Computers & Internet
Advent laptop overheating
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Display driver r300
Try K-Lite Mega Codecs pack Its A Freeware.
Click Here
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
