Question about LG DV298H DVD Player
How do i record a show to a dvd? - LG DV298H DVD Player
    Scholar:
  • 53 Answers
IF you have an LG DVD PLAYER - you will NEVER be able to record anything with it.
Suggest you exchange it for a DVD RECORDER. If your player is new, try taking it back in the original packaging and ask if you can upgrade.
Expect to pay an additional £100 ($168) more.
Posted on Nov 18, 2009
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
My Sony RDR-GX300 DVD Recorder is suddenly only recording the 1st 15 seconds from the DVR. The entire show is on the DVR. I have tried discs that I've used before successfully & new DVD's.
1) pass the Disk cleaner buy to some radio schack, and test it
2) test the cable in another device, and determine if faulty or not.
3) if not clean the terminal from DVD VS TV with c.cleaner
4) otherwise the Syscom inside and another associates circuit is faulty such like record ampl.
go to the repair shop for fix it.
God bless you
Oct 01, 2012 | Sony RDR-GX300 DVD Recorder
What should my toshiba dvd recorder say while
while recording the real time can be showing / remaing time of the event being recorded /timer clock will showcase the speed if enable or alert if there is a problem and if all is well the a red dot should also be showing
Mar 18, 2010 | Toshiba RS-TX20 DVD Recorder
After a timed recording the DVD is showing blank
Try to scan the DVD data into your PC using the trial version of TMPGEnc v4.0 Xpress if this can't find structure data then the recorder must have set the leadin data to show blank.
Nov 13, 2009 | Philips DVDR3380/05 DVD Recorder
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
DVD player won't record full time that is programed into it
There are two things are likely that can cause this: media and copyright protection. If you use DVD-RW or DVD-RAM, you should be able to copy shows ONE time onto the DVD. If you use DVD+RW, or DVD+R, it may issue a copy protection message just before it stops recording.
If the media is bad, it can also cause the machine to stop recording, I believe. You could put it into a PC and try erasing the contents before re-trying to use it in the DVD recorder.
tom
Dec 19, 2008 | LG DR787T DVD Recorder
Once we have recorded a show off the tv onto DVD we are unable to play the dvd of the recorded show on different dvd players than the one in which we recorded it off
if you are using dvd+ - R dvd disks you will need to finalize the disks on your recorder once you are done with the recording before it can be played on other players
Jul 03, 2008 | Toshiba Televison & Video
Problems playing recordings
Did you "finalize" the DVD before trying to play it in another player? This is what I have to do.
Mar 21, 2008 | Toshiba DR4 DVD Recorder
LG DV298H DVD Player Logo
Computer Repairing
Computer Repairing
