Question about InFocus Proxima DP6155 Multimedia Projector
I have an LP600. I'm on my 3rd bulb, and the two replacements bulbs have had shadows on one side or the other.
  • 2,237 Answers
It's not the lamp. you have a light tunnel that is collapsing and needs to be replaced. you'll have to send it to an infocus service center. try av solutions. they're pretty good. www.avsolutionsny.com
Posted on Nov 18, 2009
A red shadow along side images
It sounds like the lamp or light guide didn't get back in the exact original position...
Dec 08, 2013 | Sanyo PLC XW20A Multimedia Projector
What is the replacement bulb for a stanley p21/5w its the rear bulb on 2008 honda shadow
Hi, Paul for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Shadow Taillight Turn Signal Bulbs
Motorcycle Rear Brake Light Assemblies for Honda VT750C eBay
Honda VT750C2 Shadow Spirit Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C2 Owner Manual
Oct 13, 2012 | 2008 Honda VT 750 Shadow
How do I replace front turn signal?
you may have two fuse boxes.one on the side of handle bars and one on the side of the seat.check the fuses,this should fix your gauge problem.as far as the light just replace the bulb or buy new housing and replace bulb
Sep 07, 2012 | 2008 Honda VT 750 Shadow
2007 Honda VT 750 Shadow rear tail light not working
Hi, Anonymous tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1984 VT500C Tail light problem
2008 Honda Alero Shadow 750 tail light problem
http://www.partsfish.com/page/oem-parts-for-honda
Aug 30, 2012 | 2007 Honda VT 750 Shadow
1990 Honda VT 1100 C Shadow headlight stopped working
Hi, Mattbutler75 if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight problem
http://www.fireblades.org/forums/honda-cruisers/96259-honda-shadow-1100-headlight-not-working.html
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jul 07, 2012 | 1990 Honda VT 1100 C Shadow
2002 Honda VT 600 CD Shadow tail lights not working
Rear Running Light not Working Shadow Sabre
Honda VT600C Shadow VLX Service Manual
Honda VT600C Owner Manual
Feb 24, 2012 | 2002 Honda VT 600 CD Shadow
Headlight is not bright enough, possible to replace bulb or light kit or headlight
Before you replace anything make sure that the earth connection to the head light bulb fitting is securely attached on both the bulb and the frame side. Also check that the inside of the bulb is not burnt black from element deposits. If this is the case, the headlight bulb will have to be replaced.
Jan 29, 2011 | 2005 Honda VT 1100 C2 Shadow Sabre
I have a vertical shadow about 1-2 ft in width running up the right side of the projected picture. The bulb was just replaced this year and the shadow didn't start until some time after the bulb was...
The light tunnel has collapsed. Google "infocus light tunnel." You can glue it, as I did, but it tends to break again. From what I have read nobody has a good fix and the manufacturer has ignored the problem which has alienated a lot of customers. They won't even sell a replacement tunnel. Good luck!
Dec 01, 2010 | InFocus X1 Multimedia Projector
How do i change the bulb in the head light on my 2005 shadow spirit
Unscrew the head light rim, unplug the head light from the socket, un-clip or unscrew the bulb holder , and remove the bulb from the back of the lens . Replace with new bulb being careful not to touch the glass with your finger. Oil on the bulb can shorten the life of the bulb.
Sep 14, 2010 | 2005 Honda VT 750 DC Shadow Spirit
I've had my projector for years now and worked perfectly. But now, there's a shadow on the right side of the screen. I cleaned the lenses and there's still a shadow. With my observations, it looks like...
Remove the bulb, look for any obstructions or damage. If you see none. Replace the bulb, usually replacing the bulb also replaces the lens, the frame around the bulb, and other components all at once making it an easy one stop fix for most visual display problems.
Jun 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
InFocus Proxima DP6155 Multimedia Projector Logo
124 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
