Question about Garmin StreetPilot C330 GPS Receiver
Garmin won't stay on
When i turn on the Garmin C330 it stays on for a second and then powers off, i have hit the reset button but it still won't work, please advise!
  • 25 more comments
  • miko321 Feb 21, 2008
    i have not the same proplem ecthatly but when i am driving my car it suddnly turn off and when i try the power still doesn't work
  • gmckinley Feb 22, 2008
    C330 comes on for about 1 minute, then screen freezes. Have to shut off. Also sometimes comes on and then screen goes black
  • Anonymous Feb 23, 2008
    Received 330 Garmin worked fine for about 15 mins. Went OFF can't get it to come back on, reset it still nothing.
  • Anonymous Feb 27, 2008
    Garmin's battery is not dead. It will power on for a second and then just turn off. It worked fine the day before! What to do? Please help!
  • ginaky Mar 02, 2008
    MY GARMAN JUST SHUT OFF. I SWITCHED TO DIFFERENT POWER PORT, UNPLUGGED FROM UNIT AND PLUGGED BACK IN, NOTHING. THE NEXT DAY WHEN I STARTED MY CAR, IT CAME ON AND IS WORKING FINE, BUT NOW I DON'T TRUST IT!
  • Anonymous Mar 03, 2008
    Unit fired up and was manually powered off. When unit manually powered on later, it didn't power up.
  • Anonymous Mar 04, 2008
    i have a brand new garmin c 330 purchased on november 2007 ,almost 4 months now. It immediately stopped working, i couldnt turn it on or do nothing .can you please explain the reason ad what to be done.
  • Anonymous Apr 05, 2008
    My c330 will power up, but will not stay on. How do i fix this problem. Thanks gail
  • t290741 Apr 12, 2008
    Our Streetpilot c330 doesn't power on anymore. Sometimes we get a screen for a couple of seconds and then it goes dead again.
    I tried to power it on after connecting to the USB port of my computer, but this didn't help . Connecting to the mains with the transformer doesnt' help either.
    Do I have to buy another device or is there still hope?
  • Anonymous Apr 14, 2008
    shuts off about 5 seconds after being turned on, I have connected it to the USB, so I'll wait and see after a complete night of charge
  • Anonymous Apr 27, 2008
    4 month old street pilot; powers on for a few seconds only then screen goes blank. VERY frustrating.
  • Anonymous May 25, 2008
    WHERE TO FIND THE RESET BUTTON IN GARMIN STREETPILOT C 330
  • Anonymous May 27, 2008
    Have a garmin street pilot c330. worked fine for a few months, Now the screen just flashes no matter what I do.
  • madmamma May 29, 2008
    t
    Have a garmin street pilot c330. worked fine for a few months, Now the screen just flashes no matter what I do.powers on for a few seconds only then screen goes blank. VERY frustrating.I tried to power it on after connecting to the USB port of my computer, but this didn't help it won't go on.I'm very dissapointed for I was excited when I received it as a gift and now it's useless. I can not afford to buy a new one.
  • Anonymous Jun 02, 2008
    I also bought my Garmin c330 in November also. It just stopped turning on, and then yesterday it started by itself while sitting on the counter. I saw it across the room. Then, nothing. Does it seem odd that all of us bought this around the same time. I bet we got a bad batch.
  • Anonymous Jun 03, 2008
    Garmin powers up for two seconds then stops. Does this even when plugged in and after what should be a charge. Only a few months old
  • princeztessy Jul 01, 2008
    Oh man.. I also bought the c330 on black friday... powers on and wont get past the blue street pilot screen--just shuts off! Will "work" when connected to the PC, but who's going to drive around with a computer?
    Is Garmin doing anything about this?
  • nappy4 Jul 02, 2008
    Same problem. Turn on and street pilot screen comes up and then shuts off.
  • Anonymous Jul 10, 2008
    SAME PROBLEM. My unit has been a lemon from the start. It regularly loses signal and has troublel locating a satellite. This device has not given me any confidence or peace of mind.
  • charlesb41 Jul 12, 2008
    My GPS powered on for a second, powered off and won't power up any more.
  • ertichenor Jul 15, 2008
    what is the solution
  • Anonymous Jul 17, 2008
    the gamin stays on for 2 seconds and then it turns back off. I tried to reset the Garmin but it still does same thing, i also plugged it to us b
    it works but once i unplug it turns off.
  • burgan Jul 18, 2008
    will stay on when for couple minutes and then it says continue on battery power i press yes just to keep it on and it still shuts off
  • bigAl80 Jul 20, 2008
    When I unplug from power it turns off immediately
  • LD5153 Jul 24, 2008
    SAYS VERY LOW BATTERY WON'T CHARGE OR STAY ON
  • rlefkoff Dec 29, 2008
    I have a Garmin StreetPilot c340. I bought it in March 2007. From the start I had to occasionally use the reset button and then connect to the computer in order to get the screen to turn on. Now my unit is totally dead. It won't turn on at all. It is past the year warranty and I am very disappointed that I wasted my money. It should have lasted a lot longer than this. Is there anything I can do?
  • Vonwoody Dec 30, 2008
    I have the same problem, but I checked my fuse and it is still OK. But the unit seemed to power up when hooked to my computer, so I am going to charge it for three hours on the computer (manual says this long). Then, if it still does not power on; I purchased a battery to install (replacement) longer life. More than likely, it is the battery, but the garmin website still says to clean the contacts on the back of the unit with an eraser or Q-tip and see if that works. Hope this helps.
Posted on Jul 01, 2008
I am having the same problem....I found that the end of the power cord ( that plugs into the lighter ) is missing ,along with the fuse!! Sooo...I'll have to locate a new screw in end piece and fuse or get a new power cord.
Even if the end of the cord were still intact.....a blown fuse might cause the same problem.
Posted on Jul 05, 2008
  • 174 Answers
Your battery is dead. Try hooking up the unit to your computer USB port.
Posted on Jan 11, 2008
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on
I hope this helps, I had the same thing happen today. I noticed on the face under the word Garmin you can pop the face off and underneath on the right side is a reset button I held it down for 10 seconds popped the face back on and pressed the power button it came on. I hope this works for you.
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps will does not work
Feb 22, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Will not stay on
Connect the Garmin using the USB cable to your computer. Turn on your computer and let it boot up. Now turn on the Garmin. Does it stay on? If the answer is yes then the battery is dead. If the answer is no then you have something internally wrong with the Garmin. If the unit is still under warranty then get a RMA and send it back to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
2,291 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
