Question about Amana ALE443RAW Gas Dryer
How to clean internal lint buildup amana gas dryer model ALG643RBW
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 88 Answers
Buy a lint brush at Walmart or other retail store. It's a long plastic bristle brush that will allow you to reach down in to the cavity of the blower intake. I always use a vacuum hose to **** up what it pulls up so it won't fall back down in.
Posted on Nov 18, 2009
Testimonial: "Thanks much. will give it a go. "
    Scholar:
  • 53 Answers
Easiest way to remove the lint is with a vaccuum cleaner
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Model ALG643RBW Dryer heats sometime, APPEARS Flame Doesn't Always Ignite.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Amana ALG331RAW Gas Dryer
The dryer ignites but the gas valve does'nt light
Check that the gas sensor is clear or any lint/dust/crud, etc. as that could be preventing the gas valve from opening up and allowing ignition. Typically all gas dryers have a safety feature that won't allow operation if the exhaust vent pipe has excessive lint and dust in it, as that is a fire hazard.
Look in your owner's manual to see the procedures for accessing the vent exhaust and follow your specific instructions. Usally there is an access panel/door at the bottom front of the dryer that will allow you to get inside the vent, etc. Inside that is a surface mounted sensor that does a couple of things; checks for proper air (venting) flow; no excessive dust/lint buildup; and that the ignitor coil has been "lit", etc.
If any of these doesn't occur, the gas valve will not open. Follow the monthly cleaning procedure/check to make certain that the dryer is safe to use and operate.
If all the above are OK, then it is likely that the sensor has failed and needs to be replaced. You can look at the searspartsdirect.com to find your particular model using their parts diagrams and illustrations of your dryer, etc.
Glad to assist!
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
It ignites but does not heat hot enough to adequately dry clothes even though the gas is ignited. Doesn't appear to be hot enough. Amana ALG643RBW.
take the exsaust off the back of the dryer and run a load with it dettached and see if this makes a difference and let me know
Jun 21, 2009 | Amana ALG643RB Gas Dryer
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
Gas dryer won't run when pushing start. Motor not comming on.
There is a small resetable fuse athe back under the top cover being held by a plate that has a screw holding it in place. To test just connect the wires together. I see this all the time on those modeles.
Mar 15, 2009 | Amana NDG7800AW Gas Dryer
Heat in dryer not hot enough, runs cool not hot
You may have a leg of power out. First turn off the breakers, then back on to insure a good reset. Then check the wiring at the receptacle, then the plug, then the wiring to the back of the dryer. This may be the problem. Have you cleaned the lint tray?
Feb 10, 2009 | Amana ALG331RAW Gas Dryer
Gas dryer ALG643RBW ignitor glowes but no flame
Hi thanks the problem is with the coils at the gas valve 2 small coils 1 with 2 wires 1 with 3 replace Thanks THE APPLIANCE DOC
Sep 13, 2008 | Amana Dryers
Amana ALE443RAW Gas Dryer Logo
170 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
