Question about Nikon COOLPIX S52c Digital Camera
Lcd has a crack from inside. how can I replace it at a reasonable cost.
I dropped my sony cyber-shot DSC-T99, I can take pictures and can somewhat see them on the screen however there are black lines going through it. You can see a crack where the camera has fallen however not...
Yes, lcd screen is broken internally and need to be replaced but it would cost you more than camera worth, let me know if you still need part number of required lcd screen.
Jul 25, 2011 | Cameras
I have a apex 40 "lcdtv model #ld4088 and the screen cracked inside and i turn it on the cracks can be seen will that be worth to fix
Unless someone is giving away a good lcd panel that is compatible with this model or selling it/auctioning it off for a reasonable price it will cost you 80% of the cost of a new television at the least to repair this. In a lot of cases the panel itself can cost thousands of dollars (I've seen them run as much as $10,000). The labor will add to the cost. The only entities I've seen repair broken panels are the network news stations because the cost is coming from the television station and not out of anyone's pocket.
Apr 15, 2011 | Apex Digital Televison & Video
LG 42" tv LCD pannels inside tv have a cracked
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
Jan 18, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi my tv has been cracked from the inside of it how do i fix it
it depends whats cracked
if the screen is cracked the no fix- screen cost as much as the tv.
if outer frame is cracked then replace frame.
Apr 27, 2010 | Samsung LN37B530 37 in. LCD TV
Inside screen has small crack in it and only getting half of tv
For the cost of the panel, you could purchase a 65" LCD TV with a service contract and delivery. For some reason, Sharp replacement LCD panels have such a cost factor that repair is never economical. It's a sad ordeal, because they do make a reliable product (which I do recommend). I hope this was helpful, best wishes.
Apr 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My screen is cracked only on the inside.  What is a reasonable price to have the inside screen replaced?
Hi
you have defective LCD this needs to replace. this is the links to help find the lcd,. clickhere
Thanks!
Jun 05, 2009 | HTC G1 Smartphone
LCD is cracked
Check out your local Kodak Repairer for new screen cost. LCD's are not repairable only replaceable.
Mar 14, 2009 | Kodak Easyshare V1233 12.1MP Digital...
CRACK LCD TV SCREEN
The LCD panel will have to be replaced. Contact a Philips service agent for cost.
The cost of a replacement screen will probably outweigh the cost of a replacement TV.
If you have household insurance, it should cover accidental damage.
Mar 05, 2008 | Philips 37PFL5332D 37 in. LCD Television
Jvc lcd cracked screen
LCD is one of the expensive part of a Monitor. maybe you can buy a new one because if you choose to repair it, it cost the same when you buy a new one.
Feb 27, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Nikon COOLPIX S52c Digital Camera Logo
27 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
