Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer f30 code
It sounds like no water is entering washer, but I disconnected hoses, cleaned filters and checked that I have adequate water coming from the hoses. The filters entering washer were cleaned and replaced. Please help!!!
f 30 code problem.
  • 3 more comments
  • Anonymous Mar 10, 2008
    F30 code came on and beeped after a very loud grinding noise started. Whirpool Duet washer is only 7 mos old and this happened. Help.
  • lcgonz Apr 26, 2008
    I had the same problem, but viewed the utube video suggested here, and it worked like a charm! Thank you for saving me a lot of time and money!
  • banshee777 May 19, 2008
    New Whirlpool Duet front load washer. Only installed for one week and now getting an f30 fault code. Makes some clicking sounds in the soap dispenser area, but no action.
  • Anonymous May 23, 2008
    Same problem, but the Youtube video is no longer there-AGGGGGH how do I fix this?????? The first few times I was able to disconnect everything and then reconnect, run the "clean washer" and then it was all good. Now it won't do ANYTHING-HELP!!!!!!
  • spuds8084spu Apr 12, 2009
    After opening the washer mid-cycle, the F30 code appeared briefly. After trying to clear it by unplugging it, the code will not appear, it simply clicks rapidly, no matter which setting it's on.
    President:
  • 1,294 Answers
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Posted on Jan 11, 2008
Check this out...
http://www.youtube.com/watch?v=0Iu7lM9bd7c
Here shows how to fix F 30 error on Whirlpool's DUET family.
Posted on Mar 22, 2008
2 Suggested Answers
SOURCE: Whirlpool washer f30 code
Hi there.
We just bought a brand new washer and had the same thing just happen to us. Found out after taking the lid off that the top had pinched down on the mechanism that turns and allows the water to flow in. We were stacking out laundry baskets on top of the washer which did this. After taking the top lid off and touch it it began to move and is working properly now.
Have you tried this?
Hope it helps someone out there in the future if not you now.
Posted on Feb 18, 2008
My machine is Kenmore Elite front load It is
Hello Sandra,
The FH error code means the computer on the control board didn't detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced.
Thanks for using FIXYA.com
GENE
Jan 10, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo flashes FH
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
GENE
Oct 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps flashing up fh and not working
GENE
Oct 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an HF reading on my front load washer, water is going in and out. What could be the problem?
GENE
Sep 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The initials FH keeeps comin up on screen when the wash is at 26 minutes Then I have to turn off power and press start button again. What do these initials stand for?
GENE
Sep 12, 2011 | Whirlpool AWM6100 Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does LF means? and what should I do
See the following Whirlpool Service Manual for their Cabrio washer which is basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
6-1
DIAGNOSTICS & TROUBLESHOOTING
DISPLAY FAULT / ERROR CODES
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
(F30)
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
the basket but control does not detect a water level change.
• Is water supply connected and turned on?
• Are hose screens plugged?
• Is water entering the tub? If so check pressure hose connection to machine/motor control.
• See TEST #2.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi there.
Nov 25, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
2,436 people viewed this question
Dan Webster
Dan Webster
Sal De
