Question about HP Officejet 5610 All-In-One InkJet Printer
It rings but will not let the fax came through.
HP 5600 cna't receive fax; it rings but will not let the fax came through. This function worked before until I reload the program. Thank you.
  • 65 Answers
Try restoring it to factory settings and see if this helps
Posted on Nov 18, 2009
Unable to receive faxes on HP Photosmart Premium
Check the configuration set for incoming FAX and rectify the settings may resolve your problem.
Thank you for using Fixya.
Jul 22, 2010 | HP Photosmart Premium C309A All-In-One...
Will send but won't recieve fax Lexmark 5600 6600
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 13, 2010 | Office Equipment & Supplies
I HAVE JUST GOT A NEW COMPUTER AND TRYING TO RELOAD MY DISC. THE FAX IS WORKING GOING OUT BUT I AM NOT RECEIVING INCOMING FAXES
Sep 23, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 5610xi Solution Center Download?
Please go to www.hp.com and put officejet 5600 in the search bar and you will find the software program for it. If you can't find it there contact me and I will get it for you. 713-204-9111 or 585@snet.net.
Please leave me good feedback if this helped you.
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
Hp officejet 6110 all-in-one
need down lod program fo officejet6110all-one
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Trouble with the fax function
There is no setting to make this work, sorry.
This is just the nature of digital phone service. Some fax machines will work, and some won't, but generally the extremely high priced units are the one that will work (of course, right?)
It all has to do with the way the fax machine "hears" the ring, or detects the dial tone.
The only other option is to use the HP as a scanner, and send the faxes through the internet using a 3rd party fax program.
I know this is a pain, but unless you want to shell out big bucks for a new fax machine, it may be the only answer.
Apr 07, 2008 | HP OfficeJet k60xi InkJet Printer
HP 5600 all in one
For this, you need to configure your HP All in One in "answer fax calls automatically" mode.
Follow the instructions as below :
Press Setup on the panel
Press 4 then press 2 ( This selects basic fax setup and then selects auto answer )
Press > to select ON
Press OK to accept the setting.
You may like to change number of rings before auto answering the fax. You can do this by :
Press Setup
Press 4 then press 3 ( This selects Basic Fax Setup and then selects rings to answer )
Enter appropriate nuber of rings by keypad or by < OR >
Best of Luck,
rajesh_im
Feb 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp T65 program to receive faxes
press setup and change the following settings
basic fax settings:
1. auto answer : ON
2. Rings to answer = 3 rings (recommended)
Advanced fax settings:
1. distinctive ring pattern = all rings
2. ECM = OFF
3. Fax speed = slow
Feb 02, 2008 | HP OfficeJet t65 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
