Question about Car Audio & Video
My 97' s-10 has a delco stero and the signal keeps going in and out like the ant. is not pluged in all the way, but i took the dash loose and puled out the unit and made sure its in all the way. it acts like the signal its getting isnt strong enough and its stuck on one station untill it comes on then i can change the ststion,and when i get close to a large metal structor or bridge it wants to come in more but after passing it goes back to noise. is this something i can fix or is the stero bad on the inside ?
    President:
  • 676 Answers
Try a different antenna. Usualy a replacement antenna is only about 6 dollars. Try this first to make sure it is not the antenna. Even cheaper if you have at least 6 to 10 feet of wire splice one end and stick into the the antenna hole of the stereo. Extend the rest of the wire and see if signal is better. If the signal is better then the antenna needs to be replaced. If it doesn't get better, then the stereo needs to be worked on.
The only problem with that is that any delco service center will start at about $75 to look at the stereo. Replacing may be cheaper in the long run.
Posted on Nov 18, 2009
Testimonial: "thanks for the tip "
Installed aftermarket stero in GMC Z71, is you hit a bump the stero goes off
double check all your wiring and make sure all connections are tight. if there's an inline fuse holder, make sure it isnt loose. and make sure your grounding point is tight and clean. also check the fuses and wiring under the dash. if everything checks out, you've got yourself a faulty stereo.
Feb 17, 2010 | Car Audio & Video
I am trying to remove my jensen cd315x am/fm/cd receiver from my 2001 chevy silverado 2500, but can't figure out how! It has been cutting out and lights going off, I believe I might have a loose...
if im not mistaken i you have to pull your dash off then behind the dash you will have about three or four screws holding your radio in place after removing those screws you should be able to take your radio out as far as puling you dash you will need to look for about two screws usually on the bottom if not the check in to make sure before you go yanking on your dash that you have removed every screw so as you dont break it
Oct 29, 2009 | Jensen CD-315 X CD Player
Trying to set the clock on Delco Loc II 1990 Lumina
Turn the radio off. Push the set button until the : blinks. Push scan to change the hours and the seek to change the minutes. When complete, push the set button again and your done.
Mar 17, 2009 | 1990 Chevrolet Lumina
Kenwood steroe wont turn back on after few days of working
check the fuse on the back of the radio, as well as the circuit fuse sending power to the radio
Jan 14, 2009 | Kenwood Excelon KAC-X541 88W x 4 Car...
My dash lights go of when the head lights are turned on
The light switch located in the steering wheel is burnt take it apart and clen connections inside the switch
Jan 08, 2009 | 1988 Acura Legend
No signal
It sound like the ant. is cut ( this happen to me) or the ant not pluged in all the way.
Apr 26, 2008 | Audiovox XMCK10 Satellite Radio Receiver
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
