Question about Sony STR-DA555ES
Our STR-DA555ES receiver started flashing "protector fan" and now I can't do anything.
5 Suggested Answers
SOURCE: STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is 1971CJS@Bellsouth.net
Posted on Feb 28, 2008
killer_clown
  • 86 Answers
SOURCE: STR-DE915
if your preferring to protect light your either, pushing to much power, or a wire could be touching along the line. Check all your wiring even the ones behind the receiver that could be your problem
Posted on Oct 20, 2008
petraman7
  • 1175 Answers
SOURCE: My SONY STR-DE835 receiver amplifier is showing
These models are known for this issue.
I've had my share in the shop here.
Disconnect all speakers,turn speakers off, try headphones only
If it still persists then there is either :
1. power supply capacitors gone bad or 2. The thermal fuse in the transformer is open.
A tech can very easily find out if the thermal fuse is open by checking the primary of the transformer
if the plastic is shrinking away from the power supply capacitors then they've gone bad
Posted on Aug 26, 2010
  • 186 Answers
SOURCE: My STR-DE925 reciever isn't giving me any sound.
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Posted on Oct 17, 2010
Testimonial: "thanks"
Problem with SONY STR-DA555ES home stereo receiver popping & going into protector mode
You may have the speakers incorrectly connected or the speakers you are using have an impedence that is too low for the amp to support.
Sep 15, 2013 | Sony STR-DE875 Receiver
Flashing word "Protector" shows up and the sound stop on my Sony da555es receiver. I have to turn off the unit several times before the sound stays normal.
Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. I would take the unit in to a local repair shop and get a estimate of repair charges. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.
May 05, 2010 | Sony STR-DA555ES
It flashes the word - protector
Hiya,
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts (touching wires). If it cuts out, it needs to be serviced.
Regards
Mike
Mar 24, 2010 | Sony STR-DE625
Have a da555es stereo receiver. Fuses blow as soon as you plug it in to wall socket. Receiver is approx 10 yrs old and just started doing this. Any ideas?
If fuses blow out imediatelly its a sign that its something wrong in the imput area eg the power pcb or transformer pcb. try to see is there in its supply some electronical parts broken or some bad wire isolation.
Feb 18, 2010 | Sony STR-DA555ES
No power on my Sony STR-DA555ES
i went to sony's webite and called direct and got a power supply for just under 200 dollars to my door better than paying 1500 for a new one i over loaded mine and plug to may things in the back of it but the part is available
Jan 07, 2010 | Sony STR-DA555ES
Same thing
normally this happens when there is too high of an audio output. To fix this, change the system to tuner and turn down the volume (if it allows you to) and then unplug the system. Plug back in and it should work. If that doesnt work, try unplugging for 15 min to allow it to reset.
Jun 10, 2009 | Sony STR-DA555ES
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
The protector light starts flashing every time I try to use my sony tuner.
My protector light flashes on and off, whats up with the reciever ?
Jun 22, 2008 | Sony STR-GX700ES
PROTECTOR (FAN) error message - what next?
Look inside the unit. There is a fuse you can replace in the rightmost front of the unit. 125v 3.25A, I believe.
Nov 18, 2006 | Sony STR-DA555ES
Sony STR-DA555ES Logo
354 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
