Question about Sony Playstation 3 (PS3) Console
Every time i turn on my playstation 3 nuthing shows up on the screen i have tryed switching the av multi out but nuthing works
  • 5 Answers
SOURCE: A/V will not work on PS3
Their are a coulpe of different A/V settings within the A/V settings menu. Probably the easiest way may be to plug up your A/V cable and switch the TV to that input then turn the system on with the button on the front. Then trun it off with that button, by holding it down untill the system goes off. Then push the power button down again and hold it down, then the system will turn back on and beep at u, continue to hold it down, until it beeps again(5sec. maybe). This resets the system to factor settings, but do not tell it to master reset or what ever it asks you to reset on the screen when it returns, or it will mess up your saved files. Some of your saved games will not reload if you accept the reset.
Posted on Nov 26, 2009
cutie94
  • 25 Answers
SOURCE: playstation 3 not showing picture when connected,
the cable got a problem or the ps3 did...
check it out at the store
Posted on Dec 23, 2009
  • 7 Answers
SOURCE: i got my playstation 3 in december and it always
ok so,reset your playstation 3 and see if that works.second try to unplug the usb cable and blow it out then plug back in and try that.
Posted on Mar 13, 2010
Wired Xteme
  • 58 Answers
SOURCE: my playstation works fine but the screen wont appear
Try to reset your video. Make sure the red light is on in the front. Hold down the power button continuously until the system turns itself off. You should hear two beeps. If you have problems give us a call at 1-888-389-3038. We are a repair company and I can have one of our techs walk you through this. You can also check out www.wiredextreme.com.
Posted on Apr 23, 2010
rootbeer001
  • 352 Answers
SOURCE: everything connected, the screen shows but the
Try connecting the PS3 to your TV through a different port. For example, if you are using HDMI1 on your PS3, try HDMI2 or HDMI3.
Try a different cable. If you have a friend with a working cable try that.
Try a different output on the PS3. For example, if you are currently using the HDMI port, see if the standard composite or component output will work.
While convenient to plug things into an AV reciever, I find that just adds another link in the chain of devices that could go wrong.
Good luck.
Posted on Jul 14, 2010
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    My playstation 3 turns on but the av multi out doesnt work so i cant see or hear anything.
    Try resetting the display by doing the following:
    Step 1. Turn the PS3 off into standby (red light on)
    Step 2 Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
    Step 3 Wait for your PS3 to start
    Hope this helps
    Nov 29, 2010 | Sony Playstation 3 (PS3) Console
    Everything connected, the screen shows but the
    Good luck.
    Jul 14, 2010 | Sony Playstation 3 (PS3) Console
    Reset HDMI on non HDMI tv
    Put The HDMI Into your old tv then switch it to AV MULTI then put the av in then it will ask if you want to keep these setings then select yes and then put the AV MULTI into your new TV.
    Mar 21, 2009 | Sony Playstation 3 (PS3) Console
    PS3 will play on AV but will not in HDMI
    1. Connect via AV and turn on the system.
    2. Go to Setting and then Display setting
    3. Select the connector type on your TV.
    4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
    5. Your TV Screen should be on via HD cable
    Dec 09, 2008 | Sony Playstation 3 (PS3) Console
    AV multi out
    when the power is off press and hold the power button until you hear two beeps
    May 14, 2008 | Sony Playstation 3 (PS3) Console
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Ps3 wont show up on tv
    Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
    If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
    1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
    2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
    3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Nov 03, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
